In my neck of the woods
Discussion in 'Modern EPA Stoves and Fireplaces' started by Rich L, May 18, 2019.
  1. Rich L
    Rich L
    Eastern Mass.
    I see everyone has been getting a lot of rain.In my area we've been getting rain since October.Man if this much moisture is around for next winter and it gets cold we will have snow like never before.Just a thought but I'm loading up on more wood than usual just in case.
    Chaz, M2theB, Barcroftb and 7 others like this.
  2. Scout80
    Scout80
    Wisconsin
    Great minds think alike.
    also Thinking about putting up a wood shed for a few cords. I go threw 10 to 13 cords depending on how dry the wood is. I normally cut as I burn but I’m done playing that game.
    Sandhillbilly, Chaz, M2theB and 7 others like this.
  3. Rich L
    Rich L
    Eastern Mass.
    Man that's a lot of cord wood your going through each winter.What are you burning that wood in ? I'd have to be real desperate to burn any wood that's not dry.However I think it's best to be ready for some massive snow and cold coming sooner than one might expect.
    Sandhillbilly, Chaz, M2theB and 6 others like this.
  4. Scout80
    Scout80
    Wisconsin
    I’d end up with half ready to go for winter.
    Seems like time is never on my side:headbang:
    Trying to reset priorities. We bought my grandparents farm house and 13 acres and about twenty trees on the whole property. Been buying red oak by the semi load that’s all oak wilt dead stuff. Of coarse there’s still a lot of moisture in it though.
    I plan on all the wood I cut this winter will be for next winter:heidi:
    Chaz, M2theB, Barcroftb and 4 others like this.
  5. Horkn
    Where in Sconnie are you? You have to be burning in an OWB. You, as well as I, need a wood shed. I'll be building mine over the next couple it's weeks.
    Chaz, M2theB, Barcroftb and 5 others like this.
  6. Scout80
    Scout80
    Wisconsin
    I’ve got a wood boiler in the basement, next to the oil boiler that I did not use for the first time this winter.
    Im in the Pine, River Poy Sippi area
  7. chris
    you will need to split that oak small to have dry enough for this coming winter.
  8. papadave
    Scout80 , welcome aboard.
    To add to what chris said, get that Oak split now....or yesterday. You'll be farther along this coming winter than I was when we first got here and started burning.
    Water doesn't burn......:whistle::dex:Found that out REAL quick and ordered a log load the following year to give it a chance to dry a bit.
    A nice benefit from dry/drier wood is you should see at least a slight decrease in wood use, and at 13 cord/winter, I'd say you could use the relief.
    Give this a look........Primer on Woodburning by Backwoods Savage
  9. Scout80
    Scout80
    Wisconsin
    I’m starting to feel like I’m derailing Riches thread.
    I’ve got a good start.
    Got twice that cut in the woods I have permission to cut from. Will be bringing it home soon. A2239312-015A-49AB-8DFE-A52EDCE7E251.jpeg
    WoodPirate, Chaz, M2theB and 6 others like this.
  10. Rich L
    Rich L
    Eastern Mass.
    No you're not derailing the thread.This picture enhances the thread.However did you consider maybe a good stove that could heat your home and at the same time lower your wood use ? When my wood is not as seasoned as I like I purchase some compressed wood logs or blocks.I mix them in with the wood.They burn so hot the wood drys in the stove and burns well.I like the Northern Idaho energy logs the best.For the bricks I like the Canawick bricks the best.
    Chaz, Barcroftb, WeldrDave and 3 others like this.
  11. Scout80
    Scout80
    Wisconsin
    I plan on getting a free standing fireplace at some point in the future for fall/spring time.
    I clean the collector pipe once a month and the little bit of creosote that forms just inside the chimney.
    I keep a good coal base and use dry limb wood as your compressed logs.
    I don’t have an issue with how I burn wood, I’m just over needing to cut as I need it. Ive Tried to stay two cords ahead but this past winter has proved to me I must change how I’m doing it. :saw::stacker::coldfire::cheers:
    Chaz, Barcroftb, WeldrDave and 4 others like this.
  12. Chazsbetterhalf
    Chazsbetterhalf
    She needs her own little cart so she can help you. Cute pic.
    Chaz, Barcroftb, WeldrDave and 2 others like this.
  13. Backwoods Savage
    Scout80 you really need to consider getting on the 3 year plan. It will be some work getting there but in the end you will do less work as you will get more heat from your wood!
  14. Backwoods Savage
  15. Scout80
    Scout80
    Wisconsin
    That pretty much what I’m shooting for.
    I also hope to buy a semi load and get that put up as soon as funds are there. But for now it’s one load at a time.
    I’d like to get this winters cut along with next yeas put up before Christmas. One load a week I figure.
    That’s my plan now.
  16. WeldrDave
    Welcome Rich L and Scout80 ! Nice to have you folks here! I have ties to places in "Both" your states! Rich L, My family about owns half of Gloucester and Scout80 My wife is from LaCrosse. Know both states "Very well"!!! Follow the advise from the gang and get the 3 year plan going on!!! As you progress through the site, you'll see what everyone is talking about and having the best burnable dry wood for you situation. Also, everyones situation is different and we all know this, wood dries faster in Georgia then Minnesota but it's a tool/guide for having great fuel for the BTU's. :yes: Again, Welcome.
  17. Rich L
    Rich L
    Eastern Mass.
    Thank You for the cordial reception.It is well appreciated.
