Wood Insert?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Tito, May 16, 2019.
  1. Tito
    Tito
    Alabama
    I plan on purchasing and installing a wood insert soon. Any recommendations? or the ones to stay away from?
  2. Chazsbetterhalf
    Chazsbetterhalf
    Hi Tito. Welcome to the forum. I will let the more knowledgeable answer that question.
    Horkn, T.Jeff Veal and Tito like this.
  3. ReelFaster
    ReelFaster
    S.Jersey
    Welcome Tito ! As Chazsbetterhalf mentioned I'll let the more knowledgeable folks answer but it will usually start with your budget, house size, house layout, look you are going for, and room you have for the actual insert. There are many many good brands all ranging in price, heat output, aesthetics, etc...
    I'll throw my 2cents in for the Drolet!!! There are a few of us on here in the Drolet fan club which I feel gives you the best bang for your buck with outstanding customer service. But there are also many higher end brands such Napoleon, Blaze King, Quadrafire, Jotul, etc...
  4. Tito
    Tito
    Alabama
    Thank You! Im new to all this so im a big rookie :DI have a 1600ft A-frame house and the chimney is in the center of the house. The most i have to spend on a stove is about $3000. So im just looking for a good quality wood insert at a fair price.
  5. ReelFaster
    ReelFaster
    S.Jersey
    I was in the same boat few years ago, I knew nothing about inserts, still don't and still learning, LOL! $3000 is a very nice budget and should get you in some of the higher end models that not only look really nice but are of excellent quality. One thing I think most of the folks with more knowledge will say is buy bigger then you need. You can always make a smaller fire in a bigger box if the house gets to warm.
  6. T.Jeff Veal
    Here is another link for inserts.
    Wood Inserts
    I know I sent the other link on the Introduce yourself page.
    Link to Stove Builders International.
    Stove Builders International | Wood-Furnaces.net
    They make several different brands of stoves.
    A little info on them at the bottom of the Drolet page.
  7. stuckinthemuck
    stuckinthemuck
    Does $3000 include a chimney liner and installation? Tell us more about your chimney. Straight shot up? Clay flue tile? Height? Dimensions? If you need a liner and are not doing the install yourself, that could eat up a good chunk of your budget. Haven’t personally tried to climb an A-Frame but imagine you need a ladder or staging.
  8. Horkn
    Look on Craigslist or Facebook. I found my barely used quadrafire 4100i with SS liner kit for under $500. Granted I had to take it out of the house it was in, and installed it in my house, but when you get a stove that was about 3k and a SS liner for under what a new liner kit would run, that's a smoking deal.
  9. brenndatomu
    With an A frame, plan on "oversizing" the stove for the houses sq footage...as I'm sure you know they are notoriously hard to heat...you will need to run a ceiling fan in reverse all winter to keep the heat from just going to the ceiling...
  10. fox9988
    fox9988
    NW Arkansas 72717
    Fireplace size usually the limiting factor.
  11. Locust Post
    Buck stove has not been mentioned, they have several options for inserts.
  12. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Can't say enough good things about the Drolet 1800i we put in... 5 years ago? Any way... Best 900 bucks we ever spent.
  13. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Been in many an A frame on skiing holidays... Is the entire volume open or did you fill in the A?
    I'd go as big as you can fit... Or demolish the fireplace and go with a big freestanding stove. Unaware of your climate, but too me A frame means up nort
    :D
  14. Eric VW
  15. stuckinthemuck
    stuckinthemuck
    imwiley1, brenndatomu, Horkn and 3 others like this.
  16. Suburban wood snob
    Suburban wood snob
    Milwaukee
  17. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Aw hell... Alabama. Just put an electric heat bulb in the fire place and call it a day! :D
    blacktail, brenndatomu, Horkn and 3 others like this.
  18. T.Jeff Veal
    He's not from LA (Lower Alabama)
    If it's cold enough to bust a water pipe, it's cold enough for a fire...
    fox9988, Tito, stuckinthemuck and 3 others like this.
