Stihl ms290 oiling issues
Discussion in 'Chainsaws and Power Equipment' started by Andy8850, May 12, 2019.
  1. Andy8850
    Andy8850
    New jersey
    Any one have any issues with ms290 farm boss not oiling the bar well enough, cleaned the ports and it’s just pretty dry when cutting
    Hammy, M2theB, T.Jeff Veal and 3 others like this.
  2. brenndatomu
    Mine was oiling too much...had to turn it down a little just so the thing didn't leave a big ole puddle whenever I set it down.
    Have you tried turning yours up?
    Hammy, M2theB, T.Jeff Veal and 4 others like this.
  3. Andy8850
    Andy8850
    New jersey
    I have but to no avail
  4. Screwloose
    Is this a new symptom ? Look at the pickup in the tank for a plugged filter, leaking or collapsed line.
    Hammy, M2theB, T.Jeff Veal and 5 others like this.
  5. Andy8850
    Andy8850
    New jersey
    Yes, it’s a new problem, I will have to run it without the bar and see how much oil is being pumped and then see if I need to tear it down and do some exploratory surgery
    Hammy, M2theB, Screwloose and 4 others like this.
  6. amateur cutter
    This answer first.
  7. Andy8850
    Andy8850
    New jersey
    I am burning up the chain, I have turned it all the way up
  8. Backwoods Savage
  9. In the Pines
    In the Pines
    if the hose is good and the port is cleared and you are getting oil when you removed the bar than Check the bar and make sure the oil hole is clean as well.
    Clogged oil hole in the bar will not allow it to get oil.
    Check to make sure your vent is cleaned. It is by the bar studs.
    You can try putting some gas into the oil tank and see if anything comes out.
    It will help clean it up.
    If all that checks out than it is probably the pump itself.
    Hammy, M2theB, Screwloose and 5 others like this.
  10. huskihl
    huskihl
    The white plastic worm gear may be worn or sometimes the tang that the clutch drum drives is worn off and won't reach the drum. For the most part, the pumps themselves are pretty bullet proof
    Hammy, M2theB, Screwloose and 6 others like this.
  11. huskihl
    huskihl
    The clutch comes off clockwise...left hand threads
  12. huskihl
    huskihl
    Righty loosey
  13. T.Jeff Veal
    All great advice here.
  14. bocefus78
    bocefus78
    The worm gear is a semi common repair on those saws from my limited experience.
  15. Scout80
    Scout80
    Wisconsin
    I’ve had problems off and on with mine also.
    I plan on digging deeper soon
    It may be a while but I’ll try n keep ya posted if I find anything
    Hammy, Screwloose and T.Jeff Veal like this.
