Interior remodel underway
Discussion in 'The DIY Room' started by cnice_37, May 3, 2019.
  1. cnice_37
    cnice_37
    Started last summer, we opened up kitchen & dining room and beamed a wall. In the fall we did 16 double hung new construction windows. Even though I paid for install and finish work, I took on the staining and poly which took about 50 hours total!
    IMG_20180603_150123045.jpg IMG_20180610_192416187.jpg IMG_20180611_161509435.jpg IMG_20180611_161352493.jpg
  2. cnice_37
    cnice_37
    Summer was busy with pool and deck build. Deck will be in the other thread.
    Gently working my way around kitchen tile. Hope to replace the diagonals that were previously under baseboard heat with nice clean cuts and straight line (not exactly my strong suit.)
    Ripped out carpets and junk floors and particle board. Found out we only have 1/2" subfloor, so yesterday we built that up by gluing & screwing another layer on top. Much better now.
    IMG_20190420_125649988.jpg IMG_20190427_120036551.jpg IMG_20190428_205639948.jpg
  3. cnice_37
    cnice_37
    And here's where we are now. In January I also painted the entire downstairs, including ceilings, as well as upstairs bathroom and hallway. I'll have to address the oopses from ripping out flooring :headbang:
    IMG_20190503_180457673.jpg IMG_20190503_180529603.jpg IMG_20190503_180549761.jpg IMG_20190503_180603811.jpg IMG_20190503_180522444.jpg
  4. cnice_37
    cnice_37
    Chose Somerset pre-finished 3-1/4 white oak. Never floored so going to get help from a pro and see where I get when he sets me free.
    Last 2 windows (bay & casement) are also ready for install. Since I pay for someone to do those it's not as fun, but I'm no finish carpenter!
    T.Jeff Veal, Horkn, Chaz and 6 others like this.
  5. Woodwidow
    Nice work and a lot of it. Windows look great.
    T.Jeff Veal, Horkn, Chaz and 7 others like this.
  6. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Removing the wall makes a huge difference. Looking real good.:yes:
  7. cnice_37
    cnice_37
    Got about 9 boxes put down working a couple days after the paying job. Contractor got me started and gave me some tips and then set this newbie free.
    Attach43503_20190508_223652.jpg Attach43504_20190508_223652.jpg Attach43501_20190508_223652.jpg Attach43500_20190508_223652.jpg
  8. fishingpol
    fishingpol
    Very nice. Big fan of wood floors here.
    I like that the base boards are pulled too.
  9. cnice_37
    cnice_37
    We are too! We did upstairs and staircase before we moved in 12 years ago. Instead of doing downstairs too at the time, we were conservative with cash. Looking back, we should have done everything at once. Such a pain while living there, not to mention two kids in the mix now as well. Back in the day I could work until I couldn't see any more, now its no noise past 8pm - kid's ordinance.
    So by my estimation - about 450 sq ft to go.
  10. fishingpol
    fishingpol
    Been ther, done that on an occupied renovation.o_O :yes:
    We are taking on another one, but not to the extent of our first place.
  11. bogieb
    Looks a lot better with that wall opened up. I too am a fan of wood floors - and it looks like you are doing a fine job of it.
  12. Fanatical1
    Fanatical1
    Looks awesome! Good job tackling it yourself.... :yes:
  13. cnice_37
    cnice_37
    Got cut short today with a sick kiddo, still put in another 100 sq ft or so. Getting there.
  14. Horkn
    I see someone's been busy. I can fully relate.
    Your work really is paying off though. Keep at it, eventually you'll be done. Then you can work on the next project ;)
  15. don2222
    don2222
    Salem NH
    Hi -
    We have 1/2” plywood subfloors also. It is ok for the rooms with the hardwood flooring on top, but the bathroom and kitchen suffered from it. In the kitchen we added more sub flooring and then installed 3/4” hardwood.
    In the bathroom we added more sub flooring and then cement board before the tiling! No more cracked tiles because no more flexing of the flooring!!!
    Pic 1 - Kitchen floor
    Pic 2 - bathroom floor
  16. cnice_37
    cnice_37
    Closets are all that is left besides some clean up work. My daughter is 9 and she kicked some butt today. She works better than most 39 yr olds I know. I had her racking the floor and then measuring and cutting end cuts on miter. She laid a course as well.
  17. imwiley1
    imwiley1
    Wisconsin
    Looks very nice cnice_37 . You are blessed that your daughter shows an interest and helps. Memories and a bond that will last a lifetime.
    T.Jeff Veal, wildwest, Chaz and 4 others like this.
  18. CNE deer
    CNE deer
    ohio
    lots of work but looks great !
    T.Jeff Veal, wildwest, Chaz and 5 others like this.
  19. cnice_37
    cnice_37
    Grand total of about 650 sq ft, ended up around 40 hours of work which is pretty slow but I'm a rookie. Some cleanup to do and goal is to get my tile done tomorrow.
  20. don2222
    don2222
    Salem NH
    Looks great! Did you have to cut the bottom of the doors to put the wood floor in?
    Also did you raise up the baseboard heat? If there is not at least a two inch space at the bottom to let the air in, then the baseboard will be very inefficient. I found that out the hard way when I moved in and it took almost an hour for the bedroom to warm up in the winter because there was wall to wall carpet was installed and tucked under the baseboard. So I cut the nails off the back with a sawzall and then raised it up a couple inches. The bedroom warms up in 15 minutes!! That saved a lot of oil over the years!
    When we did the bathroom floor above we added cement board and additional plywood to the 1/2” subfloor so we tore out the baseboard and installed a new one on top to keep the 2 inch gap see pics below:
