Footers
Discussion in 'Everything Else (off topic)' started by Well Seasoned, May 5, 2019.
6x6 Posts, bury in crete or sit on concrete footers?
  1. Add tar to post & bury in concrete
    1 vote(s)
    12.5%
  2. Pour a footer with brackets in the concrete & sit posts on that
    7 vote(s)
    87.5%
  1. Well Seasoned
    I'm putting up a 3 sided storage area for the tractor and other things. It'll be 24ft wide and 16ft deep. 6x6 posts, strapping, metal roofing and tin sides when I can afford it.
    Environment details, we had 68mph winds a couple months ago, but it's always windy. The area i want to erect this is dry.
    I'm trying to do this as cost effective as possible
    Getting true spec pressure treated lumber, not from box store. I've read that the copper treatment in posts react to concrete. Adding tar slows any rotting.
    Looking for more advice, I'd like to bury them mainly for stability, but will pour footers if suggested. Thx
  2. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Canadian border VT had an interesting idea for installing posts but I forgot what it is. Maybe he can help. Consider a fourth side in the future. Birds get in an open build and poop all over your stuff.
  3. Bgoathill
    Bgoathill
    Dumont, Ia
    I wouldn't use any concrete at all. What I do is just set the post in the hole and backfill with crushed rock, like with what we call a 1'' roadstone, something with fines. The key is to compact every inch of the fill all the way up. Overfill the hole so any water runs away from the post, don't ever let water sit against the post. I've demoed 100 year old sheds that were built that way with just untreated logs as poles that were good as new, and 20 year old buildings with poles set in concrete that were rotted off already. That's how they set wooden power line poles and they're in it for the long haul.
  4. cnice_37
    cnice_37
    I wouldn't trust PT buried... telephone poles or locust I'd vote differently. Tar sounds like a good idea however.
    Concrete and Simpson ties, more expensive for sure.
    No building permit required?
  5. Well Seasoned
    He's helped me in the past with pouring footers then surrounding the footer with culvert piping. It worked great but I'm going a but cheaper. College coming up, I'll build strong but need to watch costs.
  6. Well Seasoned
    I like this advice....
  7. Well Seasoned
    Yes, the ties and concrete will add up, probably $500 bucks right there for good ones.
  8. Fanatical1
    Fanatical1
    You will have a lot of options that avoid the post either going in the ground or using something that protects the post from the concrete or moisture.
    Try using the national frame builders association for information (NFBA). Many members have solutions that use methods to keep the post raised or protected.
    Laminated posts are often used to provide additional strength, straightness and much better penetration of the treatment.
    If it were me, I would keep the posts above ground and use laminated posts if you plan on staying there for a long time.
  9. justdraftn
    justdraftn
    On the road
    I need some post for a graden fence. I have some treated 2x8s that I scrounged.
    I ripped them into 3" pieces. I'm going to screw them together to make 3x3 posts.
    I had a gallon asphalt sealer left from some repairs I did. I thought...why not try this.
    These are the sides that will go together. I'll treat the tops w/Thompsons.
    Finish treating the tops and bottoms after they are assembled and a detail cut on
    the top. Once the asphalt sealer drys, it is solid. I'm just going to drive them into the
    ground. Should last a few years.
  10. Canadian border VT
    Huge difference between pole barn and a deck attached to home when talking about footings..
    Challenge here is Well Seasoned location.. probably a 6-foot frost line and hurricane level wind Zone.. he is just North of Mount Washington
  11. In the Pines
    In the Pines
    they make a foam for setting poles. It's a 2 part. Never tried it, looks interesting.
  12. chris
    Foam is the best recommendation for below ground level setting of poles . just read up on that a couple months back.
  13. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    When in the Mt. Washington area, do like the locals. Chain it down.
    Sorry I really can't be of any help.
    I did work at a condominium complex where the white cedar lampposts sat in standing groundwater and rotted every few years. I ended up wrapping a new cedar post at the below grade part in ice and water shield. I used a heat gun to really get it to stick. The ice and water shield ran a few inches above ground for the much against it.
    My brother-in-law works at the same property and said the posts are still solid. That was over 15 years ago when I did them. I was real careful in the wrap job.
  14. Well Seasoned
    :thumbs:
  15. Well Seasoned
    I've decided to pour footers. The amount extra for the post bases offsets the cost of the shorter post, 16footers down to 12 foot. Will likely get better quality lumber too
  16. justdraftn
    justdraftn
    On the road
    Finished my posts today.
    Not too bad for a few crappy 2x8s.
    Should last a long time.
  17. Well Seasoned
    Nice, should work out well! :yes:
  18. JCMC
    JCMC
    Just outside of Shushan, NY
    That is probably the best way to go IMO!
  19. Well Seasoned
    I knew it was, but was hoping to save a bit, but in the end, it's probably be saying why didn't I just pour footers?
    I don't know if it'll be started or not by the g2g. I'd be tickled to have the posts up and strapped by then. Very, very busy with things, and the weather hasn't cooperated until today.
  20. Fanatical1
    Fanatical1
    Good call... Lots of options for the posts above ground with footers... :yes:
