ATV Tire Repair
Discussion in 'Chainsaws and Power Equipment' started by lukem, May 3, 2019.
  1. lukem
    I've developed a slice in the rear tire (Maxxis Bighorn) of my quad. It is about 1.5" long and right on the outside of edge of the tread, right before it goes into the sidewall.
    Obviously this is too much to ask of a tire plug. I'm not sure if an internal patch would be able to hold...and a tube would surely find its way through a hole this size.
    Should I thank the tire for its service and just buy another, or is there a decently reliable way to repair this?
    M2theB, Horkn, Chaz and 1 other person like this.
  2. Screwloose
    I think if you stopped the leak you still wouldn't feel confident in it's integrity. Always checking it and thinking about it would drive me nuts.
  3. concretegrazer
    concretegrazer
    Southwest MO
    Pics?
    M2theB and Horkn like this.
  4. ironpony
    ironpony
    Mid Ohio
    lay it to rest.........RIP dear friend
  5. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Big patch combined with a tube maybe....
    M2theB, Horkn, Chaz and 2 others like this.
  6. tree killer
    tree killer
    Central me
    Boot patch and a tube. A little harder to do with the location but doable.
    Horkn, Sandhillbilly and Chaz like this.
  7. dwyleecoyote
    dwyleecoyote
    Vermilion, OH
    I have a similar gash in the tire of my Kubota UTV. The patch held for about 2 years. About 2 years ago a tube had to be added, with the patch still in place. I would say it depends on your usage of the machine. If it is on your property where a failure won't leave you or the machine stranded, be cheap. If you are going to count on it away from other machines and tools, spend money.
    VOLKEVIN, M2theB, Horkn and 2 others like this.
  8. bogydave
    If you need reliability, replace it.
    It'll only go flat when you need it. ... LOL
    Tip...the bead on atv tires are hard to break,
    take it to a tire shop.
  9. lukem
    I think I'm going to try to do an internal patch plus a tube. These tires are stiff enough you can literally drive on them when they're flat...especially the rears...I've done it several times before. I don't want to throw a Benjamin at a new tire when a Jackson might work. If I had a long trail ride in front of me that's different....but this thing rarely gets 1/4 mile from home.
    Duane(Pa), M2theB, Horkn and 3 others like this.
  10. mark.nowak
    mark.nowak
    Sycamore, IL
    Not sure if it would work for an ATV tire but I have seen Jeep tires get stitches on the side of a trail before. Sometimes with wire or zip ties...or whatever else is available to hold the cut together.
    It’s actually pretty impressive, I think it’s worth looking into.
    M2theB, wildwest and Horkn like this.
  11. Horkn
    Sounds like a plan. Only being 1/4 mile from the house would have me try that as well.
    M2theB and wildwest like this.
  12. unbidden
    unbidden
    RI
    By the time you break it, patch it, and tube it, you're close cost wise to replacing the tire.. no?
  13. lukem
    I got it patched and tubed today. $22. New tire was $149. Worth a shot.
    unbidden and dwyleecoyote like this.
  14. MAF143
    MAF143
    North Central OH
    I made some steel rings about 4" deep that are 1/8" bigger diameter than my rims and break the beads on a press, or just put the end of a board on the tire right next to the rim and drive over the board with the tractor.
