562xp
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Apr 30, 2019.
  1. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    This is my modded 562 I gave her a bath today,shes lookin perty and smells good too 20190430_175012.jpg
    Hammy, walt, M2theB and 10 others like this.
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Did you run it before the port job. Did it make enough difference to tell about. I bought one in February and it impressed me so much, I can’t imagine what it would be like ported. Although I’ve never run (or seen one run in person) a ported saw. Picked up a 372 a couple weeks ago & been considering having it done. But I’m afraid to because then I might have to get every saw I’ll ever own done:makeitrain":makeitrain"
    Hammy, walt, M2theB and 5 others like this.
  3. CNE deer
    CNE deer
    ohio
    Hammy and amateur cutter like this.
  4. Mwalsh9152
    Mwalsh9152
    Pelham NH
  5. amateur cutter
    Yep.
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    I ran 15-20 tanks though it stock,then a pop up piston and base gasket delete,then took that piston out and made a more aggressive pop up.......took that out put in new stock piston with gasket,cut the base and the chamber.its ported,has timing advance and muff mod retaining the spark screen.this was my R&D saw to come up with a recipe for this series.runs very well:smoke:
    Hammy, M2theB, amateur cutter and 2 others like this.
