How much wood burned for 18-19 season?
Discussion in 'The Wood Pile' started by yooperdave, Apr 29, 2019.
  1. yooperdave
    Now that the end of the burn season has arrived for many of you, it will be an accurate accounting of the amount of wood you used during the 18-19 season.
    Myself, I still have the OWB in operation and hope to probably into the middle of May (typical) but the outdoor temps will dictate the final shutdown date.
    Having said that, yesterday afternoon I spent a little time in the OWB area....with a spring cleanup rake! I figure the amount burned for me this year is...…….
    right around 8 cord.
    How about you?
    M2theB, Chaz, bear 1998 and 12 others like this.
  2. papadave
    Been running the furnace more this year, so firewood use is a bit less than 1/2.......this was my master plan that actually worked the way I,uh, planned. Anyway, pretty close to 2 1/3 cord so far. I may have a small fire or a few before final shutdown, but I'm pretty much done.
    Mid-May is our normal end of season too.
    M2theB, Chaz, bear 1998 and 10 others like this.
  3. KaptJaq
    KaptJaq
    Long Island, NY
    It was a strange season here, rarely got bitter cold but stayed cold and damp all season. Only needed the second stove twice. That said, to keep the house comfortable the main stove was burned pretty hard for a longer period than usual. Normally I am just around 4 cords a season, this year I am a little over 5. Most seasons, by the end of April, I've done the spring cleanup but I am still burning evening fires, hopefully not for much longer.
    KaptJaq
    M2theB, Chaz, bear 1998 and 11 others like this.
  4. yooperdave
    Don't get me wrong, I'll still have a fire at the cottage on the weekends/mornings/evenings sort of thing.
    Its just that when the OWB gets the fires pulled, heating season is over! And that'll be in a matter of days...…..
  5. yooperdave
    Just looked at the very extended forecast (30 days) and the overnights are no higher than the 30's and 40's!
  6. stuckinthemuck
    stuckinthemuck
    Still burning. I’ll get back to you later......
  7. yooperdave
    :handshake:
    Me too. But it shouldn't be much more. I think.
  8. billb3
    A little more than last year, but didn't keep good track of what we started with and what we used. Oak is almost gone and had almost two cord to start. Have not quite a cord of red maple left and started with two. Used more pine than ever - over a cord, but that goes fast.
  9. coreboy83
    coreboy83
    NW of Twin-Cities
    We used 1-1/2 cord. It was an even split between masonry fireplace and turbo burner (soon to be replaced) Pot-Belly.
  10. Jon_E
    Jon_E
    Southwestern Vermont
    Still have the OWB running, I'll keep running it until I am out of this season's wood. I think I am at about 10 cords since September 1, maybe a bit less. I still have a brief pool heating season, and the house still needs heat on cold nights, but I hope to shut down this summer as I am having a heat pump system installed for DHW.
  11. Backwoods Savage
    Still burning almost every day. Probably have gone through around 4 cord.
  12. papadave
    Well, that didn't take long.
    Lit a fire a while ago. Cloudy, cool, with a chance of rain and snow.
    Still at 2 1//3 cord.:whistle:
    M2theB, Chazsbetterhalf, Chaz and 9 others like this.
  13. jrider
    jrider
    I burned 8-9 cords of mostly low grade junk wood and pine in my owb.
    Chaz, M2theB, Chazsbetterhalf and 8 others like this.
  14. Well Seasoned
    Same,
    but around 5 thus far
    Chaz, M2theB, Chazsbetterhalf and 9 others like this.
  15. Eric VW
    Burned a few cord, lent/traded some to new wood stove guy MarkG to get him started this past season.
    Midwinter, Chaz, M2theB and 8 others like this.
  16. Steve697
    Steve697
    Newfoundland, Canada
    Still going almost everyday still. Around the 4.5 cords mark now
    Midwinter, Chaz, M2theB and 6 others like this.
  17. Camber
    Camber
    Montana
    5 cord for the house. Maybe 1 for the garage. Probably be right around 8 by mid June.
    Midwinter, Chaz, M2theB and 4 others like this.
  18. Chris F
    Chris F
    Micksburg, Ontario
    9 to 10 full cords this year. The weather guy said the last eight months have been below normal temps for this area and I surely believe him.
    7 or 8 would be more normal for here and I'm still not done burning yet.
    Winter and cold just suck, there's no two ways about it.
    Midwinter, Steve697, Chaz and 6 others like this.
  19. JustWood
    JustWood Guest
    I don't really know how much.
    I didn't hold back at all since I knew we were moving.
    Midwinter, Chaz, M2theB and 5 others like this.
  20. OhioStihl
    OhioStihl
    Southern Ohio
    6 cords
