Some Free Wood on LI, BUT, 48"+ rounds!!
Discussion in 'The Wood Pile' started by Machria, May 9, 2014.
  1. Machria
    Machria
    Long Island, NY
    Anyone want some free wood on LI, let me know. But it is BIG stuff. I got all I could handle, but now there is some stuyff about BIG 48" across or so.... WAY too big for my saw, back, truck.....
    PM me if interested.....
  2. swags
    swags Moderator
    Would take you up on it of I was closer
    HoneyFuzz likes this.
  3. Gark
    Gark
    SW Michigan
    What... that won't fit in your stove??? Just kidding - even superman would have to leave that behind. Four feet across... WHOAZAA.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Lots of saw time for that size wood. Need a decent size bar too. Very labor intensive.
  5. thistle
    thistle
    Polk/Guthrie Counties,IA
    If I was closer would love to help ya out.
    mdavlee and HoneyFuzz like this.
  6. bogydave
    Wood type ?
    If nothing else, post some pictures. ?
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Ill leave the big wood to you fellas !
  8. swags
    swags Moderator
    You know that big stuff is a lot of work, but I really enjoyed working on bigger logs. You can get a lot of splits out of one round.
    Edit: I also cheated on that one though and had a Skdsteer to load it onto a trailer then haul it to my splitting area.
    Chvymn99 and mdavlee like this.
  9. Machria
    Machria
    Long Island, NY
    It's Red Oak.
    There were 2 rounds that were cut to 18 to 20"s that I decided to take. Well, it took a full size Caterpillar back-hoe tracker to tip them over, and hold up a few inches on one side so I could get my splitter under it in Verticle mode. It split no problem, andI said, great, now I can man-handle the 1/2's! WRONG! Still couldn't budge them, tracker helped again, and I quartered them. The qtrs, I could just barely budge (not move around) enough to slide the splitter under to 1/8 it. I think I got 1/2 cord from 2 rounds!!! Amazing, filled my entire full size F150 truck bed up, and bottomed out the shocks/springs, with "2 rounds"!!
    Anyway, my 18" Echo ain't gonna get anywhere near thru them! I could cut in from all sides, and still not be able to reach the middle! So, I drove away defeated! And it's killing me thinking they are just laying there! ;)
    mdavlee likes this.
  10. mdavlee
    mdavlee
    Noodle them babies down to manageable size. I'd much rather mess with stuff that size than 20" or less.
    Chvymn99 likes this.
  11. lukem
    Red oak should pop apart pretty easily with a maul, especially once in half. Would take much less effort than wrestling them into position on the splitter.
  12. Machria
    Machria
    Long Island, NY
    If I can't reach to cut across them with an 18" bar, how the heck am I going to noodle them with an 18" bar?? I'm still about 10" short of getting through it, and of course that is provided I have perfectly straight cuts on both sides, which would take me a minor miracle! ;)
    Ain't hapnin. Instead, I got a couple small trees in the woods near my house to top off my racks. DONE till next March when I have burnt off some of the wood I have. I've got 9 cord split and stacked, including my two sheds already full with next winters wood. So I'm in good shape.
  13. stihl sawing
    stihl sawing
    Arkansas
    If'n you was closer, I'd jump on that like a duck on a june bug.
    mdavlee likes this.
  14. Woody Stover
    Woody Stover
    Southern IN
    Noodle a series of vertical cuts from the end, then cut the slabs off from the sides.
    HDRock likes this.
  15. Machria
    Machria
    Long Island, NY
    Thanks, that's a great idea!! But I'm done with that thing.... Red Oak 1, Machria 0 ;) I've got nowhwere to put it anyway, my yard is full!
  16. Woody Stover
    Woody Stover
    Southern IN
    Wood will dry fast on the roof; There's more wind and sun. :)
    milleo and mdavlee like this.
  17. Machria
    Machria
    Long Island, NY
    You haven't seen my house, have ya?
    3 stories, and on stilts! Good LUCK getting up there! ;)
  18. Oliver1655
    Oliver1655
    Central Missouri
    To go a step further than Woody, noodle "X"s to where you have 12" sq by 17-18" long blocks when you cut them loose. Easier to handle & simple to split.
    Woody Stover likes this.
