Great example of Huffing...
Discussion in 'Modern EPA Stoves and Fireplaces' started by Woodporn, Oct 21, 2013.
  1. Woodporn
    Woodporn
    S. MA
    Saw this vid on utube and found it interesting, from what I've read the guy fully believes it is due to a faulty stove.
  2. dutch
    dutch
    Central NY
    What causes that?
  3. Gark
    Gark
    SW Michigan
    Eye-dee-ten-tee error.Notice no flames in the firebox between back-puffs.
  4. webby3650
    webby3650
    That looks like it running just like a down drafter to me!:rolleyes:
    Harmon didn't respond because there is nothing wrong. Down draft stove manufacturers won't ever admit there is any issue, it's always user error in there opinion. Lopi acted like I was the only person on planet earth to experience this smoke belching with the Leyden. I will never own another rear combustion stove!
  5. papadave
    :rofl: :lol::rofl: :lol::rofl: :lol::thumbs:
    Although, until I got the air adjusted just right last year, I had one of those.:confused:
    Little puffs of smoke from around the door gasket after a mild BOOM.
  6. Grizzly Adam
    Grizzly Adam Guest
    So... What is going on here?
  7. webby3650
    webby3650
    The secondary combustion isn't staying active. It goes out, builds up gas in the firebox and then ignites! They won't do this if the primary air is left open, only when it's shut down or if something is restricting it. But the instructions say to reduce the air once it's up to temp and the bypass is closed. I had 2 Leydens, the first one would puff like that and blow the top lid open, it went back. The second one would run away like a freight train! One night the entire back and flue collar were cherry red and the air was all the way off! They are very unpredictable to say the least. I don't expect to see any of them in production in the near future.
    reckless and Pallet Pete like this.
  8. Woodporn
    Woodporn
    S. MA
    I have yet to have any issues with my 300i
    Just sayin..
  9. Pallet Pete
    Pallet Pete Moderator
    Ovid
    We went through hell with a Harmon TL 300 I won't ever buy another downdraft stove. It was built like a tank and beautiful but a royal PITA to run. It did that all the time due to the cumbuster just not working. We added removed pipe changed caps burned kiln dried wood wet wood and on and on trying to figure it out. It's just the nature of a downdraft stove.
    webby3650 likes this.
  10. mattjm1017
    mattjm1017
    What exactly is a "down draft stove"? Ive never heard this term before.
  11. Woodporn
    Woodporn
    S. MA
    Combustion air path flows through an afterburner after a bypass is closed.
    Similar action to a cat stove
    mattjm1017 likes this.
  12. blwncrewchief
    blwncrewchief
    NorthCentral, IN
    As Webby said it is an intermittent ignition of the gasses in the stove. The right conditions can cause it in many, or in reality any, stove being secondary, cat, or downdraft. Downdrafts are just noted for being the worst due to most of the secondary combustion setups tending to be unstable. This is one of the main reasons also you want all of your flu connections on your stove pipe to be screwed together. It can and has knocked off chimney pipes before and there is nothing cool about a 500* stove pipe popping off during a burn.
  13. Well Seasoned
    Same thing can happen in any stove with an ash pan door, where when opened, even for a second or two, and after closing it, then opening the main door, the back puff is explosive and very, very dangerous! I did it once when I was a new burner, subpar wood, trying to get it going with the help of major air flow coming from the ash pan door. It got it going after closing it, but then I opened the main door and swoosh, a fireball that took at least 2 inches off my beard that year.
  14. OhioStihl
    OhioStihl
    Southern Ohio
    My old VC Encore was a puffer. Had to play with the air control and find the right spot. Sort of a pain to deal with.
    Gark likes this.
  15. Backwoods Savage
    That is about the worst one I've ever seen. Wow! It appears it is a problem with both the draft and also the wood appears to be fresh stuff but that is difficult to tell. Usually when something like this happens, there is some operator error that needs correcting as I would find it hard to believe their stove would be this bad.
    Gark likes this.
  16. Woodporn
    Woodporn
    S. MA
    I agree 100%
  17. webby3650
    webby3650
    I would have agreed with you 100% before owning one of these pieces of crap! They are unpredictable!
  18. Trilifter7
    Trilifter7
    Waynesville, OH
    I remember seeing this video last year. He had several videos and posts about it. Never heard if anything did get resolved with it. That stove was on my short list of stoves last year... Glad I didn't get it!! :cool:
  19. Oldhippie
    Oldhippie
    Ashby Ma
    That's gotta stink up the house pretty bad after a while too..
    My VC Resolute Acclaim put out a very small puff once or twice all last year, but nothing like that.
  20. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    Ah, just one of the features of a downdraft stove!
    I am super happy that I have avoided this with the VC stoves I have. I've seen several Encores do this.
