Ironwood
Discussion in 'The Wood Pile' started by Woodsnwoods, Apr 22, 2019.
  1. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
  2. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
  3. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Forget the wood! What are you driving? That thing is awesome!:thumbs:
    T.Jeff Veal, CNE deer, Slocum and 8 others like this.
  4. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Asv ST50. My newest acquisition!!!:dex:
    T.Jeff Veal, Slocum, Steve697 and 8 others like this.
  5. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I think I like your tracked toy as much, or more, than your wood scores! :salute:
    T.Jeff Veal, Slocum, Steve697 and 9 others like this.
  6. whitey
    whitey
    iowa
    Split some of that ironwood with an ax, might see some sparks at times!!
  7. Ctwoodtick
    Ctwoodtick
    Southeast ct
    Too bad it’s such a low BTU wood, lol!
    T.Jeff Veal, Slocum, Felter and 5 others like this.
  8. Backwoods Savage
    Sad that we don't have more of that stuff. I like it!
  9. Jon_E
    Jon_E
    Southwestern Vermont
    I get a lot of smaller hop hornbeam that die and fall over, the wood is always still solid, even after a few years. If it's solid enough, I take the root ball too, that's always good for a long burn in the fire pit or overnight in the wood boiler.
  10. buZZsaw BRAD
  11. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    With that tracked toy eerrrrr tool, I would be on the prowl with it all the time!!!
  12. ChipsFlyin
    ChipsFlyin
    Pittsburgh, PA
  13. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have 25 acres, but I “manage” 25 acres on each side of my property also. There is an auction coming soon with another track unit for anyone interested.......
  14. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Whacked up a quick load of ash last night before dark also. Trying to beat the rain once again A402FBDE-E773-4503-904B-234C2F098223.jpeg 0EADE4BE-2977-4DD3-8F3F-0EBD58215A47.jpeg
  15. trail twister
    trail twister
    Low BTU's or not I like iron wood as it does make heat. I am far from being a wood snob. I was just thinking about some iron wood this morning to make some wood bearings I need, Man that stuff drys hard.
    Also love the Ramps ours poped last week try to leave the roots by cutting rhe bulb just above them. I found a shortened fillet knife works well for doing that.
    :D Al
  16. Spencer
    Spencer
    Hows that thing doing in the wet conditions this spring? Looks like it is not tearing up the ground at all!!
  17. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    As long as you drive straight, it does not hurt the ground at all. It was one of my pros in the decision process since my tractor and gator wreck the woods in spring and fall wet periods. Plus, I can get pretty much anywhere now!!!
  18. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Got out my handy little bucking tool and cleaned up the entire load of iron wood. Best little helper I have for ten inch minus logs. Ground of some of the bracket years ago, but with a little common sense it works great. Strapped the 310 on it. Hard cutting with the dry ironwood. That wood is premium and went into fall 2019 stacks!!!! 1B30A76A-6539-48DD-8029-B6AE026F94AE.jpeg 50982218-5AC1-4916-A3C8-E0829EA41930.jpeg 1E7720C9-2392-4545-99D2-ADFDC324528F.jpeg C9AEB33A-4551-496E-98CE-E7828C17D699.jpeg
  19. buZZsaw BRAD
    Is that your own invention Woodsnwoods ? Nifty gadget for sure. The dead ironwood reminds me of when dad and i would cut small dead dogwoods from his woods years back. They were mostly under 4" but hard as a rock and could be burned right away
  20. T.Jeff Veal
