Lube your tools
Discussion in 'The Wood Pile' started by Suburban wood snob, Apr 20, 2019.
  1. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Tried in vain today to split 6 large 16-20“dia x 20" chunk of twisted ash trunks. Even tried a maul and an 8 lb sledge and acorn... No dice. Dreading having to noodle them...
    Went back this afternoon and lubed the splitter blade. Bam. That did the trick... A little synthetic grease on the blade and the base around the blade, working great!
  2. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Nothing like a well lubricated tool!:picard::rofl: :lol:
  3. yooperdave
  4. Moparguy
    Moparguy
    TN
    Hope to get mine lubed later today.
  5. Stlshrk
    Stlshrk
    Central Virginia
    Psa: While lube is recommended and desirable, overdoing the application of lubrication can be disastrous as well. Use with caution. :smoke:
  6. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Especially when you are trying jam it in there.
    Wherever that is.
  7. Canadian border VT
  8. JustWood
    JustWood Guest
    If all else fails ,,,,, lube yur noodler and ram it !:cool::binoculars::yes:
  9. BigPapi
    BigPapi
    The hills of Western MA
    I run a file over my wedge every so often. Helps to part the occasional gnarly crotch.
  10. Suburban wood snob
    Suburban wood snob
    Milwaukee
    That sounds painful. I will stick with the lube
