Thinking of a new stove.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Hatchetdancer, Apr 17, 2019.
  1. Hatchetdancer
    Hatchetdancer
    What’s a good replacement for a fisher mama bear. Might at some point be looking for something more efficient. Would want a glass front but one that doesn’t require a fan to operate.
  2. Maina
    Maina
    What are you trying to heat with said stove? 500 sq ft, 5000 sq ft? Well insulated house or uninsulated garage?
  3. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    SMOKE DRAGON!
  4. Hatchetdancer
    Hatchetdancer
    Approximately 900sf block ranch house. Stove is on 1st floor
    Yes I do love my smoke dragon but she is really hungry when it gets really cold
  5. yooperdave
    Let me be the first to tell just how satisfied I am with the Englander stoves I have.
    NC-13 in cottage and NC-30 in garage workshop! I got each of them at the seasons end sales at Home Depot. The 13 was first, then the 30 years later. Great stoves with secondary burn tubes and window also.
    Now, you do now that you will have to burn dry dry dry wood in these compared to what you had, right? The statement of "it burned well in my old stove, why not in the eps stove?" just won't carry any weight!
    Barcroftb, Chaz, Maina and 5 others like this.
  6. Backwoods Savage
    And I'll chip in with the Woodstock Fireview or Keystone.
    We have the Fireview. Point #1 is that you do not need a fan. The radiant heat this soapstone stove gives will heat the entire house as it has ours. Point #2 is that you will cut your wood needs a lot! How much? Nobody can say exactly but I will say our previous stove would keep us warm okay until the extreme cold hit (below 10 degrees). Then we were cold. We also used from 6 to 7 full cord of wood per season. We bought the Fireview which is a smaller stove. We went from being cold in the winter to keeping our home around 80 degrees all winter and also cut our wood needs by 50% or more. We imediately went to using 3 cord. We have also since added onto the house and our wood needs have varied from 2 1/2 cord to 4 cord or possibly a little over 4 cord this past winter (I did not keep track of the exact amount this year for some odd reason.)
    Woodstock is sold only direct and they also have a 6 month guarantee. If not satisfied, send it back and get your money back. Not too many places will do that. In addition, Woodstocks customer service is #1 all the way. Tell them Dennis sent you.
    Barcroftb, fox9988, woody5506 and 9 others like this.
  7. billb3
    Woodstock's Absolute Steel should be a good replacement for a mama bear except it won't take 24 inch logs, 19 inch is supposedly max.
    It has a fairly impressive range of output and you'll load cigar style like you've been used to, just from the side instead of the front as you get a nice viewing window (when it is clear).
    There's an awful lot of choices for non-cat stoves in the 2.5 cubic foot range as long as you don't require 24 inch log capability.
    Barcroftb, Chaz, Maina and 4 others like this.
  8. Hatchetdancer
    Hatchetdancer
    I cut my stuff between 16-20”
    However it is nice to take the longer stuff so I don’t end up with 2-12” pieces
    Barcroftb, Chaz, Maina and 3 others like this.
  9. Hatchetdancer
    Hatchetdancer
    When you say dry dry dry are you saying I need to be on the 3 year system?
    Right now I’m cutting standing dead for next year.
    Only got 3&1/2 ranks to go.
  10. yooperdave
    Yes. The wood I burned in my fisher knock off (still have it) with absolutely no issues would not burn in the epa stove I bought to replace it. After I tried with some nice old, drier, fully seasoned wood, the difference was incredible.
    Standing dead does help shorten the 3 year plan a lot, but there has only been one time that I remember cutting a standing dead maple that was used the same day that was actually dry enough to work. I was amazed.
    At any rate, yesterday would have been a good time to start hoarding some firewood...… :handshake:
    I don't regret switching to an epa stove and I think you will feel the same!
  11. Canadian border VT
  12. Backwoods Savage
    Check out this link: Primer on Woodburning by Backwoods Savage
  13. Hatchetdancer
    Hatchetdancer
    I was thinking around 2k max
  14. Hatchetdancer
    Hatchetdancer
    I’m well familiar with burning wood. With working 2nd trick it ain’t easy to make time with the wife and with Woods. Just kinda looking to be more efficient. That being said if a newfangled stove won’t hold fire for at least 12 hours I’ll stick with the smoke dragon.
    Now the stove I learned on was an Armstrong furnace
    At one point it had an oil burner and would burn coal
    Once I was able to tend fire the oil burner was long gone and we just burned coal and wood. I never trusted the coal fire and would burn more wood then anything. I might throw two shovels full of coal on over night to hold fire. The fire box on that machine was huge. It was 24” deep and 40” around.
  15. Maina
    Maina
    You’ll have no problem holding a fire overnight with any Woodstock stove unless maybe you just use pine, and you’ll reduce your wood consumption dramatically while staying at least as warm. We’re also very impressed with our Fireview. It’s a great choice for the amount of space you’re heating and a Keystone would be also. Like Backwoods Savage said, you won’t find better customer service anywhere from any company. Good luck in your search!
  16. BCB
    BCB
    USA
    IDK what its like in the OP's area but I'm seeing at least half a dozen Fireviews for sale in the local CL and FB ads. Most of them are priced around $1k.
    I keep looking for a Progressive Hybrid to pop up for sale. Very happy with my Fireview though.
  17. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Drolet Myriad... On sale at Menards for under 800, huge 3.4cubic foot firebox, great construction and a great company. Almost bought one for the garage at this price
  18. wishlist
    wishlist Guest
    I have Hearthstone Heritage that I bought new 10 years or so ago . Although I like the soapstone and the heat it hold I will NOT buy another Hearthstone.
    Mine has the front and side door . Always load from the side . If you do any research on the Heritage you will see plenty of issues with the door latch wearing out . Mine did after 6 years
    and Hearstone was/is aware of the problem .
    They made a fix with a replaceable part that could be easily installed . But they did it for just the front door ! Just plain stupid in my book . I had to do a complete tear down to install the same part that’s gonna wear again and then require another complete tear down to replace . Next time my Hearthstone will make a nice boat anchor !
  19. Backwoods Savage
    Lately there have been more bad reports. I think someone bought out Hearthstone so maybe they are having even more problems.
  20. wishlist
    wishlist Guest
    Idk Dennis ? I spoke with Jim at Hearthstone about the issue and he couldn’t give me a reason why they only fixed the front door .
    The dealer I purchased the stove from wanted $700 to repair it for labor . Hearthstone paid for the replacement part that is the same exact part that wore out . What a joke !
    I did the tear down myself , not a fun job .
