Truck brake issues
Discussion in 'The DIY Room' started by Redneck, Apr 8, 2019.
  1. Redneck
    Redneck
    Burton mi
    2000 ford f150 front drivers side brake doesn’t release in three miles yesterday had smoke coming from rotor.
    New caliper, rotor, bracket. And pads just a little while ago. Replaced for the same problem.
    What else could it be?
  2. blacksmith
    blacksmith
    central Pa
    The next easiest and cheapest thing to check/ replace is the brake hose going to the caliper. Sometimes the inside of the brake hose can break down and pieces get stuck in the caliper area. This will let fluid flow in due to the pressure but won't let it flow out when you let off the brake.
    I know this happened to me and thatth what the problem was. It may be something else but that's a good place to start.
  3. Eric VW
    This^^^^
    :yes:
  4. Redneck
    Redneck
    Burton mi
    I checked the flow compared to other side. But did not think of the return with no pressure.
    Will get a new line in am.
    Thank you blacksmith
  5. Redneck
    Redneck
    Burton mi
  6. papadave
  7. huskihl
    huskihl
    X3 or 4.
    Had a 93 Chevy 2500. 2 years old and the brakes always squealed. A guy told me the same thing. Somehow, somewhere in there a piece of rubber gets loose and flops over the hole and won't let fluid return.
  8. brenndatomu
    Yep, I have new hoses for my truck right now due to this issue...only mine is very intermittent...
  9. Eric VW
    Like as in... you don’t use the brakes often...?
    :eek:
    :hair:
    :wacky:
  10. brenndatomu
    Exactly...don't need 'em...throwing the shifter from D to R works just fine most of the time...:whistle: ;) :rofl: :lol:
    Casper, Jack Straw, eatonpcat and 4 others like this.
  11. ironpony
    ironpony
    Mid Ohio
    Blacksmith nailed it, might as well do both and bleed the whole system , again. Just did the daughters car this past Sunday.
    Jack Straw and blacksmith like this.
  12. ironpony
    ironpony
    Mid Ohio
    I run the exhaust brake on the truck barely ever use brakes.
  13. Eric VW
    I’d like to understand how that works a little better. Never had an opportunity to operate anything with that scenario.
    Jack Straw and brenndatomu like this.
  14. brenndatomu
    Well up until recent years you had to be driving an 18 wheeler to use one.
    Here is how the "Jake brake" works...there are other systems too...some just close the exhaust off.
  15. huskihl
    huskihl
    Yeah the ones available in pickups today don't work quite as well is what they do in semis LOL
    brenndatomu likes this.
  16. ironpony
    ironpony
    Mid Ohio
    not a jake brake, jake brake is mechanical and very complex built into the engine . exhaust brake uses the turbo or valve to close of exhaust off.
    Pick ups do not use jake brakes.
  17. Redneck
    Redneck
    Burton mi
    Work is getting in the way. So i Ordered both hoses today won’t be in til Thursday ( my other work day )
    And dr appt friday. So cant fix til Saturday :(
    papadave hope the popcorn holds out.
  18. blacksmith
    blacksmith
    central Pa
    Your welcome sir!:thumbs::salute: I just hope it fixes the problem keep us posted.:D
  19. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I had this problem with my plow truck, drove me crazy! I had never heard of this before. A guy at work told me what it was.
    Good luck!
    blacksmith and brenndatomu like this.
  20. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    The jake is an awesome helper.
    Back when I was into heavy trucking I owned and ran a Western Star withe a 500 Cat in it.
    I could come off a 6% grade loaded up to 105,500 pounds and never touch the air brakes..
    Ran a big rig up until 2012 when I retired...
    500 cat...18 speed Ranger tranny..
    Fun rig to drive...
    The brake hoses spoken of at the start of the thread...I agree 100%
    Many times the caliper pistons can get sticky, but in this case the hose is likely the culprit.
    Good luck on the fixumup...
    huskihl, Thor, blacksmith and 5 others like this.
