Building a holz hausen...tips?
Discussion in 'The Wood Pile' started by jrider, Apr 3, 2019.
  1. jrider
    jrider
    Taking the wood my 7 year old has split to sell in his firewood stand out front and building our first holz hausen. I’m looking for tips from those who’ve built them. What size circle did you start with? How high? Take it to a point at the top and if so how exactly?
  2. jo191145
    Haven’t built one but I’ve thought about it. Close enough? :)
    Most folks go with 8 foot base. You can use any number you want. Half the idea is to make it aesthetically pleasing so it’s all your opinion.
    Height is another matter. That’s a mix of aesthetics and practicality with a little will power thrown in. I’ve seen folks work from the inside while someone else tosses splits up to them. I imagine you need to finish the roof from a ladder or back of truck.
    Some people use a 4” pipe up the middle. The concept is as the exposed top heats it draws air into and out of the stack. True or not a plumbed pipe of some sort helps to keep it precise and round if that’s important to you. A string or wire that can slide around the pipe is a perfect measuring device. Could change the measurements to create interesting geometry shapes.
    Pics or it didn’t happen.
  3. Sourwood
    Sourwood
    Popcorn, IN
    I build mine to abou six feet. When I split wood I make a point to to make some splits flat, to make an occasional ring so the splits that are stacked will be slanted inward.
    My stacks are covered with “ shingles” the are from splitting bark off. You can alwits just use a small tarp for the top, but you will lose the chimney effect that is what makes the holshausen appealing. If you know many days of no rain is coming, remove the tarp.
    My houses are not pretty at all, if you are OCD that you will spend a lot more time on one, which is stupid- it’s wood for Pete’s sake. But then my signature statement sums up my philosophy on firewood.
    It is a good mental exercise to do one. The time you and your boy spend on it will be great. Tell folks you were getting in touch with you German roots.
  4. jrider
    jrider
    What about the center? Just throw pieces in or do you stand them up on end?
    amateur cutter, Chaz and buZZsaw BRAD like this.
  5. yooperdave
    Here you go. This'll help! But instead of a straight base, pile it in a circle. Clear as mud now, right? :rofl: :lol:
  6. buZZsaw BRAD
    thats an Egyptian holz hausen
  7. jo191145
    For drying mummies
  8. jrider
    jrider
    I'm just trying to pay respect to my German ancestors....no Egyptian in this guy that I know of!
  9. billb3
    I don't think they tip.
    Lean.
    Collapse.
    Mostly just age gracefully.
    amateur cutter, brenndatomu and Chaz like this.
  10. Chaz
    Chaz
    Southwestern NY
  11. Luneyburg
    Luneyburg
    Hills of Central Mass
    They are a wonderful way to dry wood quick and well Ill see if I can find a pic of the last one I built.
    Suggestions: Well I found a 10' base to be the best but mine were about 2 1/2 cord stacked in each one. If you have ever built a retaining wall use the same principals when building it, each row step it in a couple of inches each row and shape it to your liking. Start off outlining your 10' diameter with splits that might have a little more mass facing the outside of the stack. Fill the center of it with loose wood as it will make it extremely stable, you don't have to stack it but the more you get in there without affecting the wicking effect of it the more wood you get.
    It works splendid and a great way to stack a lot of wood in a space, let me see if I can find the picture. Found it and check out the way I stacked the perimeter the splits are perpendicular and outline the diameter of the stack you want. I did use a ladder to finish it of but was actually standing on it as well as it becomes a solid structure once complete. When you get to the top if your wood has bark stack it so the bark is up top to shed the water off like a roof.
    Cheers
  12. jrider
    jrider
    A7715619-261E-4F22-92E2-196B0F7F1158.jpeg Coming along
    Rope, Midwinter, Thor and 5 others like this.
  13. Luneyburg
    Luneyburg
    Good for you man looks good and you are ready to fill the inside of the stack, do that as you build it up it will give it stability.
  14. TurboDiesel
    Nice! :rofl: :lol::rofl: :lol::rofl: :lol:
    Midwinter, Chaz and amateur cutter like this.
  15. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    That’s mine, notice the fence I put around it to keep it together.
    Rope, Midwinter, Chaz and 8 others like this.
  16. buZZsaw BRAD
    I was poking fun of yooperdave 's pyramid diagram, meant no disrespect!
  17. yooperdave
    You did not come across disrespectful in any way.
    Midwinter, Chaz, buZZsaw BRAD and 3 others like this.
  18. Sourwood
    Sourwood
    Popcorn, IN
    For me, it is where I put the uglies, but if I ever accumulated enough nice splits to build one that way, they would be placed on end inside.
  19. Sourwood
    Sourwood
    Popcorn, IN
    That’s my style. Not creating artwork, just stacking wood.
  20. jrider
    jrider
    559E32E3-D2C3-4986-88BC-D53CBCF914D5.jpeg 6E369415-5C1F-496E-A961-AD577BB80F22.jpeg Got a fair amount done today. It went quick once I got it set up. About 1.75 cords in there so far.
    Rope, Midwinter, Woodwidow and 7 others like this.
