What's a good reliable hour meter for my new woodsplitter?
Discussion in 'Chainsaws and Power Equipment' started by Chris F, Apr 2, 2019.
  1. Chris F
    Chris F
    Micksburg, Ontario
    Cost doesn't matter, preferably not made in China. I want it to keep track for oil changes and the like.
    Here's the engine it will be going on.
    Woodsnwoods, Horkn, Chaz and 2 others like this.
  2. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
  3. Chaz
    Chaz
    Southwestern NY
    Woodsnwoods and Horkn like this.
  4. Chris F
    Chris F
    Micksburg, Ontario
    It would have to be Pepsi for me, haven't had a drink in nineteen years.
  5. Brandon Scott
    Brandon Scott
    I’m on 309 days. GOOD FOR YOU!
  6. Chaz
    Chaz
    Southwestern NY
  7. Chris F
    Chris F
    Micksburg, Ontario
    Nice looking but they all require power.
    I'm looking on Amazon and the cheap lcd's seem to be the way to go. Just a wire to wrap around the spark plug wire and battery powered.
  8. Horkn
    I'd just go that route. Not all Chinese stuff is junk. I've actually found quite a bit of decent to great stuff from China.
    This one looks good. Ip68 waterproof
  9. Horkn
    This one has a tachometer on it as well.
    Woodsnwoods, Chaz and Brandon Scott like this.
  10. Chris F
    Chris F
    Micksburg, Ontario
    I ended up buying this one. Tach and hours with a replaceable battery.
    I guess live links don't C&P too well here.
    Woodsnwoods, Brandon Scott and Chaz like this.
  11. Horkn
    They do. Just copy and paste.
    Chaz, Woodsnwoods and Brandon Scott like this.
  12. Chris F
    Chris F
    Micksburg, Ontario
    Yeah, they do make some good stuff if someone's looking over their shoulder.
    I have a first generation ipod touch that I bought around ten years ago that I have on at work for the stock market quotes and this is run all day every day and I shut it off at night and restart it every morning and it still works good.
  13. Chris F
    Chris F
    Micksburg, Ontario
    I tried my Amazon link and it just didn't show up in my post. Maybe it was too long.
  14. bigfrank
    bigfrank
    NorCal
    Chaz, Chris F, Woodsnwoods and 2 others like this.
  15. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Change oil once per year and call it good? I can’t imagine running the unit that many hours each year , at least not myself and I split a lot.
  16. Horkn
    That's all I do.
  17. Chris F
    Chris F
    Micksburg, Ontario
    Let's try it this way.
    Chaz, Horkn and Brandon Scott like this.
  18. 94BULLITT
    94BULLITT
    Frederick County, VA
    I have bought 4 cheap ones off ebay. They work fine. Just be sure you get one that you can replace the battery in. The one on my wood splitter is a nicer one. It is also a tach and has a job timer on it. It illuminates when a button is pressed. It needs a battery about every 6 months. The one on my conveyor is just an hour meter, and the battery has never been replaced. It sits outside in the cold were the wood splitter is kept in a heated garage.
    Chaz, brenndatomu, Horkn and 2 others like this.
  19. 94BULLITT
    94BULLITT
    I split more than most too. I just like have an hour meter on it to know how many hours are on it. It is also an easy way for me to track how many hours it took me to split a tandem or triaxle load of wood. I also know that I can run little better than 4 hours off a tank of gas.
    Chaz, Horkn, Brandon Scott and 2 others like this.
  20. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Going on 19 years
