Did a trimming job with a lift today
Discussion in 'The Wood Pile' started by swags, May 6, 2014.
  1. swags
    swags Moderator
    This was fun, different style of cutting then I am used to. Was in a lift cutting smaller limbs most of the day. I trimmed back two maples and a pine tree around and over a house. I really enjoyed it, and man that is more of a workout then I though it would be on the arms. Grabbing branches with one hand and tossing them over the side of the house. And running a sweet Stihl top handle!
  2. Well Seasoned
    Looking good bro!
    joshmain, HoneyFuzz and Stinny like this.
  3. bogydave
    Looks like a good "blue sky" day to be outside working.
    Amazing how many maintenance projects there is around home !
    At least you are making it fun :)
  4. DexterDay
    Nice work Swags!!
    That work definitely isn't easy.. :)
    Nice pic..
  5. Scotty Overkill
    Working the tops of a tree is definitely a different beast.....The lift makes it a little easier, but as you found out it still is work!
    Looking good bud!
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    Nice! Was it difficult to work that lift? I am considering something like that to cut back along my property line.
    joshmain and Stinny like this.
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Great pic...sounds fun !!
  8. swags
    swags Moderator
    The lift was great, and a breeze to work. It self levels and all the controls on this one are controlled with two fingers. One for speed and the other direction. Very simple.
  9. Loon
    Loon
    North of the border
    If you ever happen to bring that lift over to Canada swags, i gotta monster Maple limb over the house that needs to be dealt with. :hair: :yes:
    Stinny likes this.
  10. Stinny
    You got a pic of that?
    Loon likes this.
  11. swags
    swags Moderator
    A lift really isn't that expensive here, full day is less then $200
    Pallet Pete and Stinny like this.
  12. Stinny
    That's not bad… you can do an awful lot of things when you can "fly" around instead of using ladders. Was that the type of lift on wheels, and you can roll with it too?
  13. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Too cool swags! :thumbs:
  14. Gasifier
    Nice work Swags!
  15. swags
    swags Moderator
    This one was towed behind my truck, I just moved it around as needed.
    Stinny likes this.
  16. swags
    swags Moderator
    One more pic, the wife was holding out on this one. Didn't even know she had it.
  17. Sideshow
    Sideshow
    I have rented a similar lift twice. Once when doing roof - the one I used had short jib boom and I was able to position the basket on roof to place bundles - also used it to do lay snow and ice barrier and edge of roof work.
    Second time use to take tree down. A bit of a wabble when at full extension - one needs to "be comfortable while being uncomfortable" - i.e. get use to sway of lift. But as mentioned $200 bucks towable - other lifts much more costly. Set it up so branches dont fall on unit below..
    One word of advice - when leveling the lift - set the outriggers firmly - raise the lift up a bit with them - like when using backhoe outriggers - if you dont - you have what happened to me - got up high - shifted boom out and the machine came out of level and auto shuts off - have cell phone with you - or someone in shouting distance.
    My IS heats my home, Stinny and swags like this.
  18. HDRock
    Looks like fun work
  19. DexterDay
    Love the last pic Swags..
    Stinny likes this.
  20. Loon
    Loon
    North of the border
    One limb broke off onto the sunroom with not much damage but this one has to be dealt with as it will go through the roof for sure :hair:;)
    Stinny likes this.
