Low cost 6" inline duct fan
Discussion in 'Everything Else (off topic)' started by raybonz, May 5, 2014.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
  2. stuckinthemuck
    stuckinthemuck
    I used something similar in my fireside kiln this past winter as seen here: http://firewoodhoardersclub.com/forums/index.php?threads/what-is-it-20-questions.2393/
    Mine has a limit of 140 degrees F and never got close to that.. Highest it got was 115-120. I'm thinking about replacing it with an 8 inch inline fan to increase the airflow (and velocity in the 6 inch pipe). I think for applications that you're referring to, one could do the same using ductwork to increase the diameter to 8" and then a reducer to go back to 6" Have no idea what the code is for this stuff..
    raybonz likes this.
  3. Grizzly Adam
    Grizzly Adam Guest
    I would like to put some fans similar to this above our doorway to the living room during our remodel.
  4. Boog
    Boog
    Where my spirit is free
    I used to use one just like that to ventilate a darkroom I had in the basement. I had one of those revolving doors going into it and there was no air turnover. Installed one of those fans and I was amazed at how well it worked.
  5. stuckinthemuck
    stuckinthemuck
    We put in two of these to move air out of the stove room... Next step will be to tie them to a thermostat so they turn on automatically when the temperature gets to a certain level. I think they are a little more expensive than the inline fan but in my opinion, a little more aesthetically pleasing.. If you go above the doorway you will certainly get slightly warmer air depending on the height of you ceilings..
  6. Grizzly Adam
    Grizzly Adam Guest
    Ten foot ceilings, going to put a register vent cover in front of it to make it more aesthetically pleasing. Just an on off switch will suffice.
  7. raybonz
    raybonz Moderator
    Carver, Mass.
    Just thought the price was pretty low and free shipping too.. Dunno how long that deal will stand..
    Ray
  8. Grizzly Adam
    Grizzly Adam Guest
    They look good! I'm checking into some deals at Menards.
    raybonz likes this.
  9. stuckinthemuck
    stuckinthemuck
    Upon further review, it doesn't look like quite so good of a deal. Take a look at the pic.... The airflow direction is perpendicular to the duct.... Oh well, back to the drawing board!!!!:p
    raybonz likes this.
  10. Grizzly Adam
    Grizzly Adam Guest
    I found some room to room fans for $30 at menard, I thinking they are just what I need.
    clemsonfor likes this.
  11. My IS heats my home
    My IS heats my home
    Albany, NH
    Ray, have you got plans to install one?
  12. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    This one is an 8" but I use it to move hot air thru the wall from the stove/living room to the bedroom. It works GREAT at keeping the whole (small) house at a more even temperature with the pellet stove. I've even heard of people using ducting with these for longer runs but I think you'd want a more powerful fan for that. On low it keeps everything even and isn't too obtrusive noise wise when going to sleep or hanging out in either room.
    http://www.amazon.com/Suncourt-TW108-ThruWall-Room-Fan/dp/B004I5H22C
  13. raybonz
    raybonz Moderator
    Carver, Mass.
    LOL I saw that too..
  14. nate
    nate Banned
    Palmer, AK
    "Perfect for ventilation of Grow Room" :whistle::zip:
    RockyMtnHigh, raybonz and Boog like this.
  15. clemsonfor
    I
    was gonna say i have seen just what you want on amazon. They mount in wall between rooms and are either round or square with register covers.
  16. clemsonfor
    But as we all know you want to move cold air to the stove room.
  17. Grizzly Adam
    Grizzly Adam Guest
    Of course.
  18. RockyMtnHigh
    RockyMtnHigh
    Bailey, Colorado
    I installed mine both ways and it actually worked better to move the warm air into the bedroom where it makes it's way to the bathroom then eventually runs through the hallway into the kitchen where the tstat is. Maybe my situation is rare but I tested it with a thermometer and how long it took to warm up etc. lol
    I'm such a nerd sometimes :D
    raybonz likes this.
