Professional Tree trimmers/loggers, how much is this going to cost?
Discussion in 'Everything Else (off topic)' started by Casper, Mar 23, 2019.
  1. JustWood
    JustWood Guest
    Nah, that was pure negligence.
    There is no gray area in felling.
  2. Casper
    Casper
    The guy cutting said he had a strap, (not sure what he meant) around the tree and released it a few minutes too early.
  3. Chazsbetterhalf
    Chazsbetterhalf
    When I enlarged it, i did see a cable wrapped around a big branch.
  4. Casper
    Casper
    I haven't been down there yet. Maybe on Monday. I see what your talking about though. I'd like to know if it baberchaired.
  5. ironpony
    ironpony
    Mid Ohio
    Bulldoze it and start over it will never be right again
  6. Casper
    Casper
    I'd be interested in seeing the crack in the basement wall. I wonder if it is possible to crack the footer. If it's cracked I'd bet that's what they do. A few neighbors said they felt a shake when it hit. Makes sense with it hitting the brick wall, thus transmitting energy to the foundation.
  7. brenndatomu
    Just what I was thinking too...
  8. Locust Post
    Wrong crew, should have had Scotty out to drop it. :smoke:
  9. Casper
    Casper
  10. brenndatomu
    Looks like they cut their hinge too...
  11. Casper
    Casper
    Sure does, the fence is open in the direction of the red arrow. It fell in the direction of the green.
  12. bogieb
    Her insurance should be talking to the tree company's insurance. Also, if she has a loan, it might be good to inform the bank as they have a lot invested to ensure the house is fixed correctly.
    A lawyer is not a bad idea, and maybe even an independent adjusters report on what needs to be done.
  13. Backwoods Savage
    Never a good thing when this sort of thing happens.
    Chvymn99, Casper, Screwloose and 3 others like this.
  14. JustWood
    JustWood Guest
    The stump looks sound in that pic.
    I'd be curious to see a view standing over the stump.
    A lot can be told from the cuts made
  15. TurboDiesel
    OH yeah, thats gonna be expensive!:doh:
  16. TurboDiesel
    Glad everyone is Ok!!
    Including the tree crew...that could've been really bad!
  17. Canadian border VT
    I wouldn't even know where to start to fix that!!!
    Only thing I'm sure of is the insurance company will try to lowball you!!!
  18. rottiman
    Turning the ignition switch on a D-4 or 320 Cat Excavator will probably be the best bet...................................
    Jack Straw, Chvymn99, bogieb and 9 others like this.
  19. Canadian border VT
    If foundation is broken probably true!
    Jack Straw, Chvymn99, bogieb and 8 others like this.
  20. DNH
    DNH
    Missouri
    Glad no one was injured and people are stepping up to do what is right!
    Never delt with this before but rough numbers from where I’m at minimum prices for the known damage.
    Excavation to inspect foundation and repair cracked wall 15-30k
    Two Brick walls rebuild 20-25k
    New roof 20-25k
    Interior work 15k most likely 50-75k
    ~80k minimum most likely 2-3x that.
    Now that’s just the individual cost the biggest factor is can’t safely work in it without repairing the roof and shouldn’t fix roof without fixing the foundation first!
    I’d say if the house is not worth 350k plus zero chance insurance will repair it!
    Chaz, Midwinter, Jack Straw and 2 others like this.
