How do you know it's time for a new bar?
Discussion in 'Chainsaws and Power Equipment' started by theburtman, Mar 20, 2019.
  1. theburtman
    theburtman
    What are the signs or symptoms that it is time for a new bar?
  2. Screwloose
    Well..... when the drivers don't clear the bottom of the groove. If you can't squeeze the rails in any more. Other than physical damage it's hard to wear one out. What issues are you having ?
  3. Junkyard
    Junkyard
    Claremore, OK
    If it looks like the last letter of the alphabet it’s time lol.
    I’ve dug many a bar out of the bin at the local mower shop and fixed them fairly easy. A little file, hammer and grinding is all it takes. I have seen a few that were never flipped and used in a particular way a lot so they develop a worn spot beyond what you can clean up.
  4. hotshot
    hotshot
    USA
    When they quit serving you drinks, and accuse you of having too much! :rofl: :lol:
    Seriously though, put a straight edge up against the bar & a cutter, then look for a gap where the cutter holds the straight edge away from the bar (a gap is good).
    Madsens1.com has a good article on that, under ‘Bar & Saw Chain’, then go to ‘Guide Bar Maintenance’.
  5. papadave
    The one on the right looks a bit like the one I'm about to toss.
  6. theburtman
    theburtman
    My chainsaw hasn't been cutting great lately and I wasn't sure if it was the bar or frozen wood.
  7. Farmchuck
    Farmchuck
    Nepa
    Great information!:yes:
  8. theburtman
    theburtman
    I did the straight edge test and it is time for a new bar. Thanks
  9. The Wood Wolverine
    I have a 37" bar that the groove is V'd on. I've tried many different methods to close the rails, all with no success. So I found a 42 to replace it.
  10. Backwoods Savage
    Think I've only worn out one bar in my short life here on Mother Earth. I did bend one once though...
  11. papadave
    Me too. Well, a tree did the bending, but it was my fault.
  12. Screwloose
    In my opinion........ groove wear is more of a problem for people who for some reason or another don't run a sharp chain. Long before the saw starts cutting a curve the chain is being pushed to the side. All it takes is one side being a little bit sharper and the chain will favor that side.
  13. papadave
    Or in my case, someone who took too long to learn how to properly file. :picard: Chain is always sharp, but I was messing up the angles from one side to the other.
  14. TurboDiesel
    Welcome to the club, theburtman !:handshake:
    i think you're gonna like it here!:yes:
  15. papadave
    Oh man.......I missed he's a new hire.
    Welcome aboard theburtman !
  16. Chaz
    Chaz
    Southwestern NY
    :cheers:
    I was gonna run with this...
    But I missed the opportunity.
    :doh:
    I'll try to do better.
    :rofl: :lol::rofl: :lol:
  17. robertb
    robertb
    USA
    That's the best information and illustration I've ever seen on determining bar wear.
  18. Ashwatcher
    Ashwatcher
    West By God Viginia
    Welcome theburtman and robertb , you’re gonna like it here, I guarantee it! We like pics, dogs and beer. We also like spending your money on accoutrements to enhance your addiction,,,errr, meant hoard. If you want to buy something, just ask and you’ll be flooded with encouragement,,,,,its that easy! Great folks here eager to lend advice or a hand.
    Nice to meet you :handshake:
  19. T.Jeff Veal
    X2... great folks on here from all walks of life and all over the world.
  20. hovlandhomestead
    hovlandhomestead
    MN
    I have had a number of saws in my life, but currently have three in the shed, the oldest going back to the early 1990's. I have never replaced a bar on any of them. They are all used in a random rotation depending on the job required. And I am sure I have unwittingly flipped the bar on them when replacing chains which probably has helped, and while I have cut a lot of firewood, I am certainly no logger or professional.
    I did notice last fall that the sprocket on the end of my 18" husky 51 was a little sticky, so I cleaned it with WD-40, then lubed it up with Fluid Film, and haven't thought about since, until now. Which is a good thing, as I will be more mindful now of such matters with all the good information I have learned here.
