What's your opinion on this?
Discussion in 'Chainsaws and Power Equipment' started by Gasifier, Apr 30, 2014.
  1. the GOAT
    the GOAT Banned
    I'd add a receiver hitch to the back of that carryall and get a splitter that drops the rounds on the tongue end. You could toss that splits right into the carryall and with a good out feed table they may just fall right into place. And then just drive to the next tree.
    Gasifier and MasterMech like this.
  2. Gasifier
    Hmmmmm
    Wait. Wrong one.
    Doh!
    Doh! Doh!
    upload_2014-5-1_18-29-14.jpeg There it is.
  3. basod
    basod
    Mount Cheaha AL
    That's your log lift right there back that box to table and pickaroon them onto the splitter table - never handle rounds twice is my moto.
    Or you build a feeder rail from the box to the table and roll the rounds down to you - may have to find a hill to set the tractor on or depression to set the splitter in
  4. SolarandWood
    SolarandWood
    Syracuse NY
    This is on the north side of Syracuse. Most of the stuff I see in your pics is straight and relatively small diameter. Seems like a horizontal with a 4 way would be the most efficient way to turn that stuff into boiler food. Lift that carryall up to working height and run it through.
    http://syracuse.craigslist.org/hvo/4435124121.html
    Gasifier likes this.
  5. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Not sure if this has been pointed out but 3 point also requires a tractor for use. What happens if you don't have one someday? With a gas splitter you rely on a motor but it's attached. If it dies then the motor is far cheaper than a tractor.
    Stinny and jetjr like this.
  6. Gasifier
    True Pete. True. But with 83ish acres of land now I don't think I'll ever be without a tractor again. That would almost be like you being without pallets! LOFL!
    Anywho. I think I have decided to go with a self contained gas unit. Will be deciding this week.
    jetjr and Pallet Pete like this.
  7. Stinny
    Oooooooh… splitter sleep over… need pics.
    Fanatical1 and Gasifier like this.
  8. MasterMech
    American makes some great splitters! Local to you upstaters too. That machine would be incredible with a 16gpm pump and a 8-9 HP engine..... :whistle:
  9. jetjr
    jetjr
    Pa/Md line
    I would say find the one with the most features you like and then modify it if you can't get everything you want.
    Gasifier, the GOAT and Stinny like this.
  10. Tiewire
    Tiewire
    Missouri
    Have you thought about making you're own. It can be exactly the way you want it then.
  11. Stinny
    That's a really nice pic and set-up! I've seen a couple like this on YT and liked em a lot. You're so right… add on whatever you need after you have the splitter you want. I wanted a long lift line that retracted fast instead of your set length lift line. I went with a pre-positioned hydraulic raise (by hand) and the up/down lift line for making it possible to go more side to side on the ground, then lift to where I've set the boom head directly above the splitter. And, they all fight gravity just fine… :yes:
    Tiewire and jetjr like this.
  12. thewoodlands
    thewoodlands
    Our local Stihl dealer sells them, not far from Gasifier, we purchased a 24 ton Vertical/Horizontal 305cc back in 2008.
    MasterMech and Stinny like this.
  13. thewoodlands
    thewoodlands
    Have you been to the Wood Chop Shop to look at the Oregon splitters, they look like they're well built, a 20 ton will split anything I have or you have.
  14. jetjr
    jetjr
    Pa/Md line
    I did not really want a splitter when I got mine. Found a decent deal on a 3pt homemade job and ended up buying a pump had an old wheel horse and put old ugly together. PHOTO_20140501_171942.jpg I angle it close to where I want to stack the wood, let the splits pile up and keep pushing themselves closer to the stack. I do like splitting horizontal but want to put a table on the off side and a lift sometime down the road.
    Pallet Pete likes this.
  15. Gasifier
    Unfortunately I am not a welder fabricator. Wish I was!
    Pallet Pete and Stinny like this.
  16. Gasifier
    Your splitter is an American? I remember seeing them at the Wood Chop Shop several times. I don't think they sell them anymore though. ?
  17. Gasifier
    Hmmmm. How much? I have checked them out before but have forgot how much they cost. Seems they were right up there with the Iron and Oaks. ?
  18. thewoodlands
    thewoodlands
    They have them in the Massena store, you'll pay more but they're built to last.
    MasterMech likes this.
  19. Gasifier
    They have an American there? Here, they have an Oregon 20 ton. The manager told me they have a 28 ton Oregon in Canton. I haven't been to the Canton store in a while. They have the best service there.
  20. Stinny
    :axe::axe::axe::axe::axe::axe::axe::axe:… is it time?
    the GOAT likes this.
