No bark = no ash.
Discussion in 'The Wood Pile' started by JDU, Mar 9, 2019.
  1. JDU
    JDU
    Perry County, PA
    Last few weeks have been burning insect killed oak that the bark sloughed off while the tree was still standing or was loose enough to fall off when cutting to firewood length and or when splitting. That and solid hardwood blocks from the pallet mill. I have not had to shovel out ashes once in all that time. Amazing the difference between that and ash and oak firewood with bark on, I'd be shoveling out ashes every other day! DSC05128.JPG
  2. Backwoods Savage
    True that wood bark will give logs of ashes but not enough to make me want to get the bark off all the wood.
  3. farmer steve
    farmer steve
    top of the hill york co. PA.
    Hi JDU. Nice looking stack. What part of purry co.?:)
  4. bushpilot
    bushpilot
    Eastern Washington
    I am with you on this. Bark burns and gives heat, why would I go through the work to remove it? Of course if it is barkless due to the work of mother nature, I don't complain.
  5. buZZsaw BRAD
    interesting observation. Cant say ive ever paid attention to that as most of the wood i cut is green.
    FatBoy85, Woodsnwoods, M2theB and 7 others like this.
  6. JDU
    JDU
    Perry County, PA
    Beside Little Buffalo State Park.....top of a hill like you apparently.
  7. Mwalsh9152
    Mwalsh9152
    Pelham NH
    On my larger rounds I've started popping the sap wood and bark off and tossing it aside for shoulder season. Then I have nice square blocks of oak to pack the stove with.
    Hellcat, Woodsnwoods, M2theB and 11 others like this.
  8. farmer steve
    farmer steve
    Lived up that way back in the 80's. Out past the Newport reservoir if it's Stihl there .
  9. billb3
    "No bark = no ash" = hyperbole
    "No bark = less ash" = reasonable to believe
    Some bark actually has at least slightly more BTU content than the wood itself with the trade-off of ( a little/some) more ash.
    Most of my oak is four years seasoned and the bark is falling/fallen off. I don't burn it. I pile it up. I don't go chopping it off though. It falls off in the stack and in the process of handling it and I toss it in a pile. In a pile on the ground near the woods the tree roots get into it surprisingly fast and this isn't surprising given that much inner bark is edible and loaded with starches, minerals, fiber, sugars - all manner of digestible nutrients for people, animals and for sure other living things like trees.
    Having not made a habit of eating bark I imagine that, like beans, my digestive process would have a hard time digesting these newfound fibers and end up fermenting them in the colon much to the chagrin of cohabitating partner(s) and passers-by.
    Plus bark is supposed to make a pretty good potting medium ground up. Some nurseries pay for large quantities of (ground up) bark.
  10. JDU
    JDU
    Perry County, PA
    Correct...less ash, not none. Also, I did read that some bark has a little more btu value, but on average about 10x more ash content. And there is a mulch place near here that deals strictly in bark mulch, supposed to be much better than the ground up wood mulch.
  11. Horkn
    Yeah, more bark= more ash and less bark= less ash.
    With black walnut, the bark wants to fall off after a couple of months, so I'll remove it as I'm bringing it into the stacks to get burnt. Having nice dry bark dress help to get coals into flames though.
  12. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    I remove 90+ percent of bark. Only leave that which is really stuck. More than one reason.
    First, I compost and shred all of it for gardening. More valuable for that, than for heat.
    Second, the wood is drier, faster, as the bark holds moisture in the wood.
    Third, eliminates most bugs. Not all, but most.
    Fourth, cleaner, with fewer ashes.
    Finally, helps smooth things out, and keep my stress level manageable. Much cheaper than a therapist, and even with splitting everything by hand, moving the wood with a wheelbarrow almost exclusively, huge garden, tons of heavy labor, lots of beer and tobacco use, the bark removal process is good medicine.
  13. Canadian border VT
    My ash debarks itself when drying, cherry and maple less so.
    mat60, JDU, Woodsnwoods and 6 others like this.
  14. Winston
    Winston
    Maryland
    Totally agree! I don’t like burning black walnut because of the bark. It is hands down the messiest wood in my stacks and I have a no more black walnut scrounge rule now because it’s so messy and makes so much ash. Pieces without the bark are fine but I am not going to get covered in black dirt that stains to take it off.
    mat60, JDU, Woodsnwoods and 4 others like this.
  15. Midwinter
    I'm a bark remover too! As much as I can, I take thick bark off oak, maple, and black locust. Thin bark I don't bother with. I do it to stymie the borers, to speed up drying, and to save space. And it is relaxing.
    I agree, barkless oak makes very little ash. But barkless red maple makes double the ash the debarked oak makes. And barkless elm leaves a ton!
  16. jo191145
    I certainly like my bark to come off. Easier for the wood to dry. As someone mentioned I’ll split the bark off In thinner slabs. Err, well I used too. Now that I’m years ahead I’m not worrying about it as much. Get to split bigger too.
    mat60, JDU, Woodsnwoods and 2 others like this.
  17. NH mountain man
    NH mountain man
    WMNF N.H.
    When I'm splitting, any bark and splitter chips that are on the ground I rake up and put in milk crates that go in the splitter shed for a year to dry. I use that stuff for kindling, it works great. 4 or 5 crates get me through a season of burning.
    Road-side Oak, JDU, mat60 and 3 others like this.
  18. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I have started popping bark off on big rounds,18 inch diameter plus. I try to pop it off with the thumb on my excavator. Usually my logs are down for 6-12 months and it pops right off. I use it to start fires usually. Wood dries so much better without the bark. I do think hickory bark is made of steel once dry though, man it is hard.
    mat60, Midwinter and JDU like this.
  19. MaineMtnMan
    MaineMtnMan
    How is everyone removing bark?
    mat60, buZZsaw BRAD and yooperdave like this.
  20. yooperdave
    I burn mine off the chunk! Why throw away btu's, right?
