Suggestions to add some grip to a wooden axe handle
Discussion in 'Axes, Mauls, and Hand Saws' started by Screwloose, Mar 5, 2019.
  1. Screwloose
    Hello all. I have always used linseed oil on my handles and some are getting as slippery as a snot on a dog's nose. My grip isn't what it used to be so I'm wondering what is available to possibly wrap them. In the past I've used friction tape but does a better alternative exist ?
    Midwinter, amateur cutter and Chaz like this.
  2. Dancan
    Dancan
    ns canada
    If you look at a GB maul handle you'll see they give you extra grip without a big swell .
    I hope it shows in the pic.
    I've also scraped down a linseeded haft and reapplied fresh linseed .
  3. Screwloose
    So they cut grooves in it ? I think that is what I'm seeing. That sure looks like a nice piece of equipment, I'm especially liking the haft guard.
    Midwinter and Dancan like this.
  4. Dancan
    Dancan
    ns canada
    I have an older version of that one , I like it .
    The guard works very well , I made a similar one to protect another maul that I have .
    I believe that the groves are there from the copy lathe that they use , very effective .
    Midwinter and Screwloose like this.
  5. mr.finn
    mr.finn
    Mass
    How about hockey tape or what they use to wrap tennis raquet handles.
  6. Mag Craft
    I use parachord. I drill a small hole at one end to put the chord in and smear epoxy on the area I am going to wrap and then put a small hole at the other end cut the chord to length and tuck the end in.
    I have never had it come apart on any of the mauls, axes, or hatchet's that I have done.
  7. Screwloose
    That's interesting, I'll look into that. Thanks
    Woodwhore and Midwinter like this.
  8. metalcuttr
    metalcuttr
    western WA
    You could try filing some rings into your handle with a fresh chainsaw file. Carefully draw about 8 or 9 rings around the handle in the area that you need more grip in. File a groove about only about 1/4 of the file dia. into the wood. Sand till it feels right and seal. Don't go too deep or you will find that you will develop blisters after a hard day of splitting! Guys always used to do that on framing hammers!
  9. Woodwhore
    Woodwhore
    Mason NH
    Hello friends, Dave Canterbury has a video where he uses something like a piece of steel heated with a torch or you could use a woodburning pen. Anyway he uses the heated piece to etch (burn) lines into the length of his axe in 1 inch increments so he has a way of measuring things. I think that might work and look kinda cool on the end of an axe for some grip. Heres the link, i think the ruler is a nice touch too
    Screwloose likes this.
