Fun repairing home PC
Discussion in 'Everything Else (off topic)' started by Horkn, Jan 14, 2019.
  1. Chaz
    Chaz
    Southwestern NY
    Horkn you should be able to add the old drive on the SATA cable and access it as secondary drive.
    You will need the new/existing drive as primary since it's running the OS.
    There are also adaptors that allow you to hook up the old drive via USB, and access the drive easily.
    papadave and brenndatomu like this.
  2. Grizzly Adam
    Grizzly Adam Guest
    brenndatomu and Chaz like this.
  3. Chaz
    Chaz
    Southwestern NY
    brenndatomu likes this.
  4. papadave
    The cable probably won't work, since it's a platter drive. Prolly need a power source, so either put it in the case, or get an external enclosure. Oops, just noticed the box says power included. Never mind.
    SSDs can use a non-powered cable. Makes for an awesome external, portable drive setup.
    Chaz likes this.
