  1. NorthernCrew454
    NorthernCrew454
    NE WI
    Hi All,
    I got the 4" stainless liner installed and the T put together at the bottom that extends out of the chimney. Now, at the vertical and horizontal T connection, is there a typical way to seal this joint? Since its in a chimney I only have access to the inside of the joint shown in the picture.
    Thanks!
    ivanhoe and imacman like this.
  2. stuckinthemuck
    stuckinthemuck
  3. Lousyweather
    Lousyweather
    should be able to reach into the snout and fingertip apply RTV to the joint
    ivanhoe, imacman and stuckinthemuck like this.
  4. NorthernCrew454
    NorthernCrew454
    NE WI
    Yes, I can get my hand in there and I have some of that permatex on hand. Thanks!
  5. jtakeman
    I'd use the rutland rtv which is rated for higher temps. Over 1000ºF ifn I remembered correctly. :) Stove cement is also a good choice and rated for 2000ºF. Hard as a rock though and a b1tch to get off if you ever have too.
    Make sure you knead it into the joint too, Don't just smear over it. ;)
    stuckinthemuck, ivanhoe and imacman like this.
