Echo cs800p advise needed.
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Feb 20, 2019.
  1. Screwloose
    Some friends of mine (would be inlaw's if my flipping kid would pop the question) own a resale shop. He calls to offer me a 7 month old saw for a song. Well I sang, like most of this chorus here would.
    So I tear into it to do a muffler mod thinking it would have a cat to gut. I was surprised to find a empty can with a exhaust port with a deflector welded over it. It looks like the port is already bigger than the carb so what now ? Caps from the carb are in the trash. Anyone mod one of these ??
    A look at the Piston
    The saw came with some cans of vp 40-1 fuel supposably only had one can's worth of run time.
    Thanks for any advice.
  2. amateur cutter
    I'll give you some advice: Send it here & I'll break it in for ya! Nice find. Muffler empty & port not restricted, tune it & run it like ya stole it! If it needs more send it for a port job. Those seem to be really solid saws.
  3. tamarack
    tamarack
    paulina oregon
    I'm no saw builder, but I have ran an echo 800 before. Put that gutted muffler back on and tune her in. Those saws remind me of the old McCulloch or pioneer saws from the eighties, lots of torque! It will pull a 32 or 36 inch bar with full comp in softwoods with no issues. They don't have the chainspeed of the Stihl or Husqvarna or dolmar. Cs800 is kinda heavy but I think one would last a lifetime if taken car of.
  4. Screwloose
    I already have 2 cs8000's the grey ones. No issues in over 20 years with either EXCEPT for the flipping chain brakes !! Those have been in a drawer for about 20 years !! On this one the brake is mounted on the clutch cover itself so that's a big improvement. Also the new style cylinder and piston. Still the crappy air filter though.
    amateur cutter likes this.
  5. Screwloose
    Actually the 8000 will pull a 36" full comp semi in hardwood no problems. I'm only thinking that this should be better.
  6. Screwloose
    I never ran a ported saw before, is it really that much different ?
  7. Eric VW
    Doesn’t Pallet Pete keep a few Echo saws under his pillow or on the nightstand?
    :whistle:
    :D
  8. Eric VW
    Does a bear chit in the woods?
  9. amateur cutter
    Yes! 30% or more power & speed in the cut for the same weight.
    Barcroftb, Screwloose and Eric VW like this.
  10. Screwloose
    So.....if I was to go down the slippery slope of having a saw ported who do you recommend ?
    Barcroftb and amateur cutter like this.
  11. Screwloose
    So I take it your on the ported bandwagon also ?
    Eric VW and amateur cutter like this.
  12. amateur cutter
    Kevin aka huskihl has done two for me & they're great runners. Mastermind is world famous as well. I've got an 044 he did & it's a great saw too. Not sure he does anything but new saws though.
  13. Eric VW
    Not yet...:whistle:
    Seen plenty in action at some GTG’s:salute:
  14. Screwloose
    What is the typical cost ?
  15. amateur cutter
    I think it varies on different saws. My two smaller saws l had less than $500.00 into. The 044 I bought ported. Well worth doing on a known healthy saw imo.
    Barcroftb, huskihl and Screwloose like this.
  16. huskihl
    huskihl
    :dremel::salute:
  17. Screwloose
    The man of hour !!!! What are your thoughts on this ? I haven't run it yet as I took to dumping the fluids and minor disassembly for inspection, limiter cap removal ect. I don't expect any issues though. I'm hoping to get it together this weekend and fire it up set the carb ect.
    amateur cutter and huskihl like this.
  18. huskihl
    huskihl
    Sounds like a great place to start.
    I haven't handled an 800. I'd venture to guess they're a larger brother to the 670/680, which I've ported a few of. A bit heavy compared to saws from Stihl and Husky, but build quality is 2nd to none. Taken care of, I think they'll last forever.
  19. Screwloose
    I don't carry them around all day so the weight doesn't bother me. I have the 680 also as my small saw no issues at all. I like metal.....lots of it. I'd really like to port it myself but while I have the tools I don't know squat on what I'm after. I'm intrigued with the idea of sending it out though. Might have to schmooze the war department a bit. My son the traitor said to her "I don't understand why he bought a 3rd one"
  20. Canadian border VT
    So he can grow up and use the small one and help you.
