Started work on a new parking lot
Discussion in 'The DIY Room' started by mike bayerl, Feb 17, 2019.
  1. mike bayerl
    mike bayerl
    Got the Kubota out today and started clearing a spot next to the lane ( guessing 20'x20'). Used some leftover asphalt millings to begin the leveling. As usual, there is a boulder sticking up ain the center. Once I get it near level, I'm planning to put down a layer of geotextile follwed by crusher run stone.
    Chaz, Slocum, mat60 and 1 other person like this.
  2. shack
    shack
    Upstate NY
    The Geo T is nice stuff, keeps the base from sinking out of site if you have soft or wet area. Looks like a good project.
    Chaz, Slocum, mat60 and 2 others like this.
  3. mike bayerl
    mike bayerl
    It's soft and wet...
  4. Chazsbetterhalf
    Chazsbetterhalf
    Where do you get the geo t stuff?
    Slocum, mat60 and Screwloose like this.
  5. mike bayerl
    mike bayerl
    Don't know yet...
    Chaz, Slocum and mat60 like this.
  6. TurboDiesel
    Mike. You'll get a much better finish if you put 2's or 3's down first then top with a 2A type of stone. The Geo and twos will make a nice base layer that will not sink or move around and will sort of make a bridge over the soft stuff. The 2A (similar to crusher run) will fill in all the gaps in the larger stones and nit it all together keeping them from moving and give you a nice smooth top. Once its all compacted, it will get like concrete. And of course, the geo will keep the mud from pushing up through.
    Chaz, Slocum, brenndatomu and 2 others like this.
  7. mike bayerl
    mike bayerl
    Thank you TurboDiesel. For now, I have a couple more scoops of asphalt millings to level out the surface. Are you saying put 2-3's down before or after the geotex? I'd like to do this once, right rather than having to redo it in a couple years. BTW, I also have another ~50x50' area for our sheep that is currently a mudfest, that I want to put stone on to get it dry-ish for them.
  8. Canadian border VT
    I would put geotex down first.. Prevents rocks from being pushed into mud..
  9. Will C
    Will C
    New York
    Definitely put geo fabric between native soil and any aggregate. You'll want to have 6" or more of gravel on top of the geo fabric for future maintenance-blading, raking, etc.
  10. schlot
    schlot
    NW Iowa
    Depends on the fabric or grid on placement of granular material. Check with your supplier. Most construction supply places (not big box lumber yards) will supply you with material and company rep to talk to.
  11. Canadian border VT
    Your local town road commissioner or excavation company will tell you.
    Chaz, Chazsbetterhalf, Slocum and 2 others like this.
  12. TurboDiesel
    Geo first, to separate the mud from the stone. then mud doesn't come up through the geo, and the stones won't sink into the mud.
    Chaz, Slocum, mike bayerl and 2 others like this.
  13. Will C
    Will C
    New York
    My brother buys Geo from his septic tank supplier-it is used to seperate the sand filter from the back fill material. Might be another place to look for it. I think he buys it in 300'x 13' wide rolls.
  14. TurboDiesel
    Try New Enterprise Stone and Lime.
    LB Water
    Landscape Supply places.
    its Expensive! but I'd get the woven geo.
  15. mike bayerl
    mike bayerl
    Thanks buddy! I was prepared for the $$$, because I had already been looking into it plus stone for doing some runoff/mud management in the sheep pasture. 2 birds w/ 1 stone...
  16. TurboDiesel
    You're welcome, :yes:
    id try to find cheap shale for the sheep pasture
  17. Flamestead
    Flamestead
    Windsor County, VT
    Chaz and TurboDiesel like this.
  18. mike bayerl
    mike bayerl
  19. mike bayerl
    mike bayerl
    I found a local supplier. They sell a 12.5' x 100' roll that they call a "driveway kit" so I don't have to buy the full 400' roll! That should help with the budget.
