Small job yesterday
Discussion in 'The Wood Pile' started by bang, Jan 28, 2019.
  1. bang
    bang
    South central Indiana
    This cherry was a leaner and was shading a dogwood and butterfly bush so I decided to drop it while trying out a saw. I needed to put it between a bird feeder and butterfly bush and dropped it in the middle. This one was only about 14" but for practice I notched it and did a plunge cut behind the hinge and then cut out, worked perfectly. 20190128_085831.jpg 20190128_085750.jpg
    Reloader, Snigg, Log Dog III and 25 others like this.
  2. ReelFaster
    ReelFaster
    S.Jersey
  3. billb3
    The vine on the cherry looks like creeper, but what's on the two trees to either side of it ?
  4. bang
    bang
    I dont know, there are vines close by 3 to 4 " diameter. I cut several yesterday to kill them. I call them grape vines but not sure I'm correct on that.
  5. TurboDiesel
    Thats the perfect place for a plunge cut:yes:
  6. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I call it creeper, and it causes me to get severe blisters which last for days or weeks!!! My wife does not get even an itch from it....nice work. I love cherry for morning and shoulder season times.
  7. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    :hair:Poison Ivy!! :faint:
    JoeinO, bear 1998, M2theB and 3 others like this.
  8. billb3
    I'm thinking friend of Batman here and quite possibly a NSFW image.
  9. bang
    bang
    I made an attempt to move this wood and some other firewood around it to the area where I split and stack my wood and it didnt work out. Using my quad with a trailer(holds about 1/4 facecord) my plan was to haul a load to my stacks and return with seasoned wood for my racks on the porch and shop. I started fairly early but the ground thawed quickly and I was slopping around so much that I had to stop after 3 rounds.
  10. Boogeyman
    Boogeyman
    Central Indiana
    I decided to not even make an attempt this morning, it's been so wet and it won't freeze and stay frozen. This kind of weather drives me nuts! Good job on the leaner bang!
  11. B.Brown
    B.Brown
    USA
    Hmmmmm, i'd call it poison ivy if your getting blisters. You mention your ''wife does not get even an itch from it". Take that as a ''sign'' it's probably poison ivy.
    T.Jeff Veal, bang, Midwinter and 2 others like this.
  12. Locust Post
    That's the perfect size, one split down the middle.
    Backwoods Savage and bang like this.
  13. bang
    bang
    poison oak or ivy has no effect on me so I dont worry about it but I do pull off the vines as I load it.
    Backwoods Savage and T.Jeff Veal like this.
  14. Canadian border VT
    Great job bang !!
    bang and Backwoods Savage like this.
  15. buZZsaw BRAD
    May very well be poison ivy. Seems like whenever i cut cherry there is always a vine of some sort on it. Ill have to post a pic some time.
  16. buZZsaw BRAD
    great job! Ive never felled a tree using that technique. Ill have to try it some time. I usually notch then cut from the back tapping a couple wood wedges in the kerf. Have a huge white oak to drop and im a bit nervous about it. Makes it a lot easier when they are leaning!
