Where to buy bulk wax?
Discussion in 'The Wood Pile' started by ksks, Feb 10, 2019.
  1. Greenstick
    Greenstick
    I just leave it in that pot, and slowly bring back up to temp next time with new candles and have had no problems. I do it out in the garage because I am nowhere near careful enough and my wife would end up killing me if I did this in the house and spilled. I am not sure if it is from my dripping on the side of the pot but I do get some smoking going on, or I may get the wax beyond its smoke point if wax has a smoke point like cooking oil does?
    Chazsbetterhalf and Chaz like this.
  2. billb3
    <<nitpicking>>
    Actually,
    Wax doesn't burn. If it did candles would never work.
    Wax/parafin has a flash point of about 200ºC or about 375ºF
    This can be maintained fairly well at the tip of a wick with the introduction of a flame.
    It's the invisible vapors that can start forming on top of wax that is far too hot that can ignite.
    Using boiling water as a medium minimizes the possibility of creating a flash point.
    As with chocolate and custard you don't need all the heat a stove can provide. Plus an open flame such as a gas burner has can be dangerous around vapors.
    A drop of wax dropped on a red hot electric coil can induce a flame as well, so use the double boiler no matter what stove top you have..
    A coffee can or another pan inside a larger pan of warm water is a good enough buffer.
    Chaz and Erik B like this.
  3. blacktail
    blacktail
    PNW
    I put the saw dust/chips in the egg cartons and then pour the wax in them. After they cool I break them apart and put them in a plastic tub that I keep near the stove.
    For my last couple of batches I used noodles and they're a pain to work with. IMG_20190109_231039869.jpg
    Chazsbetterhalf likes this.
  4. Greenstick
    Greenstick
    The reason I mix in chips to wax is the noodles are a pain, and I found doing chips in a carton then pouring wax over seemed to float the chips out and end up with mostly wax and a mess of chips pushed up and out all over.
  5. Chazsbetterhalf
    Chazsbetterhalf
    Thanks
    Greenstick likes this.
  6. Woodwidow
    I can only add my endorsement to these comments. No matter where you melt the wax, use a double boiler for safety and keep a lid near by to put on the pot if you get a flame. Be careful what you put the liquid wax into as well. Much to my surprise, some plastics melt when you pour liquid wax into them.
    Midwinter and OldJack like this.
  7. DBH
    DBH Banned
    Downeast, Maine
    Newespapers....read them, then recycle in the stove. Prescription . :cool:
    What's all this wax thing ?
