24 inch bar
Discussion in 'Chainsaws and Power Equipment' started by Osage Orange, Apr 30, 2014.
  1. Osage Orange
    Osage Orange
    Does anyone make a 24 inch bar for a Jred 2260 running .325 chain? Probably should have went with 3/8 chain on this saw but was trying to standardize chain inventory. Now find myself needing a 24 inch bar on occasion.
  2. w8ye
    w8ye
    Mansfield, Ohio
    All you need to do is put a 3/8" rim on the saw with a 3/8" X 24" K295 bar
    Just do this for when you need the big bar. Otherwise, run your .325
    The 2260 has a inboard clutch with the rim sprocket on the outside where you can easily get to it and change the sprocket with your scrench. Wrong!
    HoneyFuzz, DexterDay and HDRock like this.
  3. DexterDay
    Really? I wonder why they made the 550 and 562 with outboard?
    I like Husq, but dislike Outboard clutches.
  4. w8ye
    w8ye
    Mansfield, Ohio
    I looked on the IPL for the 560 and it showed the clutch with the rim on the outside?
    I have a 545 and a 550XP and their sprocket is on the inside.
    You are correct, the rim is on the inside on a 560. They just turned the picture around.
    I saw a picture in the service manual and they showed the worm being driven by the hub on the the clutch bell so it has to have the rim on the inside.
    I stand corrected.
  5. Osage Orange
    Osage Orange
    My 2260 has outboard clutch. Thought if I could find a bar I could skip taking off clutch to change sproket.
  6. Osage Orange
    Osage Orange
    May have to look into investing in a ms362 cm to run the 24 inch bar.:)
    draftgear and clemsonfor like this.
  7. w8ye
    w8ye
    Mansfield, Ohio
    I can take clutches off in a hurry in the shop but I never tried it in the woods?
  8. Osage Orange
    Osage Orange
    What is the best way to get the clutch off? Last one I did I took off the flywheel cover in order to get a grip on flywheel to keep crank from turning while screwing clutch off. Surely there is a quicker way.
  9. w8ye
    w8ye
    Mansfield, Ohio
    With my Husqvarna's, I use the clutch tool and a 1/2" impact wrench. It works so quick that I usually don't use anything soft in the combustion chamber to hold the piston.
    On my Dolmar 115 I used a flat nose punch and a 2 lb hammer but I had the plug out and a soft piston stop in the chamber.
    Osage Orange likes this.
  10. Osage Orange
    Osage Orange
    Agree that outboard clutches are a pain but does seem to allow for better balanced saw in my opinion.
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I would just get another saw to "keep" the 24 inch bar on all the time !!
  12. MasterMech
    That's still a lot of bar for a 60cc saw. If I was spending the money for a saw to run a 24" bar full time, it would be a 70cc machine.
    That said, it is still far less $$ to buy a 3/8"-7 rim, a 24" and an 18" bar, two loops for each and call it a day.
  13. HittinSteel
    HittinSteel
    Wooster, Ohio
    Insert piston stop. Turn clutch clockwise with proper tool or socket.
    Ive never heard so much to do about so little in the inboard vs. outboard debate.
  14. Osage Orange
    Osage Orange
    Anyone know which clutch tool fits 2260? Not having much luck with Baileys help line.
  15. w8ye
    w8ye
    Mansfield, Ohio
