Finicky starting stove today
Discussion in 'Everything Else (off topic)' started by blacktail, Feb 5, 2019.
  1. blacktail
    blacktail
    PNW
    No smoke once it got warmed up though. Somebody wanted her ball thrown in the snow all day, so I fired up the hand warmer. IMG_20190204_104358334_HDR~2.jpg IMG_20190204_165311930.jpg IMG_20190204_104633931_HDR~2.jpg IMG_20190204_104745858_HDR~2.jpg IMG_20190204_172641733~2.jpg
  2. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    Sir, the wood stove is supposed to be installed inside your home. ;)
  3. Chvymn99
    :rofl: :lol::rofl: :lol::rofl: :lol:...
    blacktail - nice little setup... Love the last picture....:yes:
    tamarack, brenndatomu, HDRock and 7 others like this.
  4. stuckinthemuck
    stuckinthemuck
    I believe it is also an option to build a home around one’s wood stove.... most of us just do it the other way...;)
  5. MikeSs
    MikeSs
    new have county, ct.
    He trying to warm it up outside!
  6. Canadian border VT
    Hey nothing wrong with an outside heater;)
    brenndatomu, HDRock and yooperdave like this.
  7. yooperdave
    Start throwing tires and railroad ties in that firebox then!
    Casper, brenndatomu and HDRock like this.
  8. HDRock
    This is comical .
    Great pics man love it :thumbs:
    No need for a pan of water on top of the stove :whistle:
    brenndatomu, Chvymn99 and TurboDiesel like this.
  9. blacktail
    blacktail
    PNW
    Very disappointed in this stove. I don't know what square footage it's rated for, but it barely heats 40 square feet of my yard.
    Thor, Jack Straw, papadave and 5 others like this.
  10. Chvymn99
    You might check and see about there return policy? How long have you had it?
    What percentage of moisture does your wood have? Make sure you use a fresh split when checking...
    Hopefully that helps...
    Thor, Jack Straw, blacktail and 3 others like this.
  11. yooperdave
    OK, now the fun begins!
    First, over analyze everything about it. Size, height, configuration of chimney would be a great start. Then, consider the wood's MC but don't do anything about it. After that, start picking apart the stove's design and list all the things that should've/could've been done with it. Finally, after months of possible over firing, begin to notice how the door itself doesn't quite operate up to par. Then, take all this info to the manufacturer....even though you never registered it for warranty purposes......and keep up the constant b!tching and whining about such a sub-standard product until you finally get some reprieve.
    Seems to work! :rofl: :lol:
    Thor, Jack Straw, blacktail and 5 others like this.
  12. TurboDiesel
    was your wood dry when you cut it down?
  13. brenndatomu
    Then give it the boot! :whistle: ;)
  14. papadave
    See, this was my first thought as well. Check your gaskets. Are you using Pine or Oak?
    You might need to consider not only square footage, but cubic footage also. How high is the sky?:whistle:
  15. billb3
    You might need a bigger stove if you're trying to dissuade the global warming deniers.
    yooperdave and Chvymn99 like this.
