Lessons learned - 1st year hoarding
Discussion in 'The Wood Pile' started by Gourley, Jan 31, 2019.
  1. Gourley
    Gourley
    LaPorte, Indiana
    This was really my first year of doing some firewood hoarding; or the way I see it investing in the future.
    1. Pine will cause a chimney fire or pine is fine.
    One of the first types of rounds I was able to get was pine and the other one being elm. I got a fiskers maul and went to town first on the pine and got through all of it after many nights after work and felt great about it once it was done. During the splitting, I was getting a rash every single time on my arms and it would not go away. I wore long sleeve and did not come in contact with the bark and I stopped getting the rash. I then built a fire with it and stood in the smoke to find out the smoke did not bother me one bit more than any other smoke. I then decided to grill out on a fire with pine and ate the food; that did not bother me either so the only issue was bark to skin contact. Nearly everyone I talked to about starting to use the fireplace warned me about having a chimney fire if I used the pine so that was moved out to the fire pit to be used during the year. Later I learned about how many other people use pine around the world and it is fine as long as you burn clean wood. I have taken some of that wood and use it daily for kindling to start a fire or a small split to bring a fire back to life that has started to die down. My kids have even learned the name of the pine because they love the poping it creates when one is thrown in.
    2. Not all wood is a pain to split
    As I stated I started with just that pine and some elm. Those branches in the pine create one heck of a round to try and split when the entire tree is covered by them. A good portion of them I had to hit it like I hate it. I got through all of them and rolled out the 8 or so rounds of elm that I have. I was able to make it through I think about 2 of those rounds before I gave up. The grain on those had a twist tighter than a candy cane and after fighting for a full night to make one of those rounds give me my 4 wedges back I knew those were not worth my time and maybe they will be easier another day. Sometimes I go out to them and go to pound town on one after a bad day of work until I am beat. The pile never gets any smaller but it is a great way to unwind after a bad day. The next type of wood I got was ash and boy was I ready to put a hurting into those logs. After the first few rounds I found out how much different each type of wood can be when splitting and boy was I happy. Since then I have had the chance to split other types of wood and have been pretty happy with all other types I have had a chance to split.
    3. Only hard wood is the wood worth burning
    This kind of goes with the pine one but I decided to make another number for this alone. On my first year I was pretty well guided to focus on getting only hard wood and what many would consider to be prime since that is the only wood worth burning. I probably had the chance to get some quick drying soft wood that I could have been burning duing the warmer burning times this year but instead have been using my wood that I have collected and now looking back on it I feel like a fool. This will make a little more sense when I get to my next number.
    4. The wife needs a fire nearly always
    So I only have so much hard wood ready to burn but my wife looks outside and sees what she thinks is an endless supply of wood to burn. Rainy day in July? Better make a fire since it is dreary outside. Burning season starts before Halloween and ends when it is 50 or 60+ every day. Having all that soft wood would really help keep up with her desire to burn in the old fireplace 24/7.
    5. Leaving decent sized branches behind is a waste
    After cutting up a down red oak without a top and one that the top was still I got to see how much extra wood that is in the crown that can be added to the woodpile. Anything forearm size is big enough to go into the stack and even smaller stuff can be grabbed for kindling if needed. Rest of the stuff I have tried to create a few brush piles away from the house in hopes that the mice will have a place to live that is not with me.
    6. Sadly I can't trust our dog
    The dog will jump up on the other side of a huge log that I am trying to roll over nearly crushing me. She will also jump on top of the same log that I am currently cutting with the chainsaw nearly getting had. I don't want to be hurt or deal with a dieing dog just because she is still young and wild so she has to say in while the saw is running.
    7. I don't need new tools and toys
    But oh man they should make everything easier. I have one saw, a few axes, a maul, some wedges and a few felling wedges and I can get by. The things that would be nice to have to me right now are some type of atv with a cart to go along so I don't need to use the wheelbarrow or the sled to move wood around. A truck to get wood from a place that is not my property would be nice; sure is a bummer to pass up on some good scores since I don't have a truck. Have something like a peavey sure would help to roll those big logs around and make sure the saw does not go into the dirt. Upgrading the fireplace to a wood stove or an insert is the dream but for now I don't need new tools and toys.
    Those are a few things that I have been thinking about but for now my wife is calling me for dinner.
  2. saewoody
    saewoody
    Central CT
    Great write and definitely some accurate assessments. Keep up the good work!
  3. Eric VW
    Let this be the first thing you add to the mix... the heat radiated and the subsequent cessation of interior air going up the chimney w/ the fireplace will really please your firebug wife:yes:
    Also, great write up. :salute:
    Be mindful tho of daydreaming when running your saw or swinging the maul... :headbang: :eek:
    :D
  4. Midwinter
    Softwood is great to have on hand, I agree, great for those 40° plus days. Sounds like you have the motivation to build a mighty hoard, and I hope you can get an insert or stove in the future.
  5. M2theB
    M2theB
    Central Massachusetts
    That was excellent!!
  6. Reloader
    Reloader
    NW Oregon
    I had a young lab who wanted to go after anything that had a motor on it. She would snap at the chainsaw and constantly harass the riding lawn mower. So much so, she had to stay inside when I was running a saw. One day the lawn mower threw a rock that caught her in the side. No permanent damage but it cured her of wanting to be close to anything with a motor on it.
  7. Gourley
    Gourley
    LaPorte, Indiana
    What is there left to daydream about when I am running the saw or swinging the maul? Splitting really is my favorite step of the labor portion. Watching it season warms my heart every time I look at one of the piles as well.
  8. TurboDiesel
    Ruger loves to run along side the atv when i'm on it. He must have got his toes pinched a few times by sticks going under the tires. Now when he sees a stick moving next the the atv he'll stop and wait till it quits moving then make his way back up beside me.
  9. Gourley
    Gourley
    LaPorte, Indiana
    We had a dog that went nuts every time the weedwacker was on and would bite at it and often get bloodied. After that happening a few times we no longer used that tool. That very same dog ran away from any basketball acting like it was a live grenade.
  10. Chaz
    Chaz
    Southwestern NY
    Great write-up
    :thumbs:
    Always lessons to be learned for sure.
  11. hovlandhomestead
    hovlandhomestead
    MN
    I can relate to item # 4 in particular!
    It is good to have a wife that likes the fire, meaning they will support us acquiring all the items you mentioned in # 7 :thumbs:
  12. MikeInMa
    Good start! Get yourself a second saw. The day will come when the one you have, won't start when you want it to.
    Hoard on!
  13. whitey
    whitey
    iowa
    "Hit it like you hate it"--not only did I laugh, but I totally relate to this. Splitting is just as good mentally as it is physically.
    Screwloose, Loon, WeldrDave and 9 others like this.
  14. trooper
    trooper
    Arizona: It's a Dry Heat!
    I can totally relate to splitting after a bad day at work! Got me through lots of stressful times.
    Great post Gourley. I definitely agree with others that recommend getting a stove or an insert. You will see your wood usage drop DRAMATICALLY.
  15. bushpilot
    bushpilot
    Eastern Washington
    If you ever decide they were right about the pine, we have a few folks here more than happy to relieve you of those stacks that are in your way ;)
  16. TurboDiesel
    more heat AND less wood usage.
    Win. Win
  17. gboutdoors
    gboutdoors
    S.E. Massachusetts
    Great post two things though WE LIKE PICTURES:thumbs: Then I have this advice on the pine DON’T burn it if you do your dog will leave, your family will stop talking to you and your neighbor will come over and drink all your beer!!!! So send me your address and I will come get rid of it for you because that’s the kind of guy l am.:D
  18. Backwoods Savage
    Ruger also loves to run ahead of the atv! Must be very careful lest you run over the poor dog. lol
  19. Backwoods Savage
    On the contrary, I used only one saw for longer than most on this forum have burned wood and it was not a problem.
  20. Backwoods Savage
    Gourley that is a good write-up. I will comment on a couple things. On the splitting with wedges. For sure having 4 wedges you should never get them all stuck. I always used 3 wedges and if the first one did not split the log, I used 2 wedges together to spread that crack wider so you can get the first one out. And I can relate to splitting being a favorite or one of the favorites of putting up wood as I did it by hand many, many moons. Still, when I was forced to go hydraulics, I found that I love splitting even more!
    By all means get a free standing stove or insert as soon as you can. For sure you will use less wood and it will give you much more heat than you are getting now. This means less work and more comfort. That is hard to beat.
    Not sure if you've ever read this but: Primer on Woodburning by Backwoods Savage
