A bit nippy here in Wisconsin...
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by krooser, Jan 31, 2019.
  1. krooser
    krooser
    Waupaca, WI
    -29F this morning... had the old St. Croix turned up to #3 on the dial. Also turned on a small ceramic heater to keep the kitchen a but warmer.
    I guess it's time to either rehang our kitchen door or find some better weatherstripping as that old wind was coming in around the door... it's kinda catty wampus in the door frame.
    ttdberg, imacman, PelletHound and 7 others like this.
  2. jtakeman
    ttdberg, imacman, badbob and 4 others like this.
  3. chris
    Going to have to do something about the seals on the casement windows every single one is leaking with the 30+ mph winds and the -30 temps. i had replaced all the glass panels in Nov. so at least I do not have solid sheets of ice for windows this season, unlike last year. going to warm up this week end might try some thin foam adhesive strips where the bulb seals contact. It was way too expensive to replace the windows completely. Also need to put a motorized damper on the HRV 6" intake duct
    ttdberg, imacman, badbob and 3 others like this.
  4. peterfield
    peterfield
    I remember a storm a few years ago when snowflakes were blowing into the breakfast room through the door jamb. Told the wife it was probably time to buy a replacement door.
    ttdberg, imacman, mike bayerl and 4 others like this.
  5. heat seeker
    heat seeker
    Connecticut North Central
    It's a balmy -1º here this morning. I pity those out in the midwest!
    ttdberg, imacman, ivanhoe and 3 others like this.
  6. jtakeman
    It waz negative 8 here this am, Ain't gonna get any warmer tomorrow neither. Just less wind chill. :loco: :crazy:
    :doh:
    ttdberg, imacman, CleanFire and 3 others like this.
  7. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    -11° this am.....no bugs or snakes:banana::banana:
    ttdberg, imacman, Earl764 and 3 others like this.
  8. badbob
    badbob
    partial sun,40 degrees,worked on the backhoe in a long sleeve shirt-------------------
    ttdberg, imacman, jtakeman and 2 others like this.
  9. badbob
    badbob
    Interior storm windows?A church out of Maine has a great website showing how to make them,cheaply.
  10. CleanFire
    CleanFire
    I miss 40 degrees right now. :(
    ttdberg, imacman, ivanhoe and 2 others like this.
  11. jtakeman
    o_O
    -11 by the lake and warmed to -9 down the hill.......... And they said it would be warmer dis morning?? :zip:
  12. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    I got -9°this am
  13. jtakeman
    :eek: Its a freakin heat wave...................... :faint:
    :doh:
    badbob, ttdberg, imacman and 3 others like this.
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Burnin some fuel fo sure...blaze king wood stove goin,2 pellet stoves goin,an oil fired furnace,and a 280000 btu waste oil furnace
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Did you go to the lake this morning to check the hatch??
    badbob, ttdberg, jtakeman and 3 others like this.
  16. jtakeman
    NO!
    ivanhoe, CleanFire, ttdberg and 2 others like this.
  17. chris
    Interior storms- been thinking along those lines
    badbob, ivanhoe, CleanFire and 2 others like this.
  18. Rich250
    Rich250
    Berks County PA.
    :bug:you got the winders open skeeter
    badbob, ivanhoe, imacman and 3 others like this.
  19. jtakeman
    Most likely!! :rofl: :lol:
    :doh:
  20. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Only -8° this am:loco: :crazy:
    ivanhoe likes this.
