Scrounging six cords a year plus
Discussion in 'The Wood Pile' started by Rowerwet, Mar 6, 2018.
  1. T.Jeff Veal
    Wow, I thought DHT were good splitters. Our County Line has no problems.
    Hammy and brenndatomu like this.
  2. Rowerwet
    Rowerwet
    Seacoast NH/MA
    this is the kind of performance i'm used to, the DHT just stops on this kind of wood. I'm going to look into how to bump up the pressure, since it seems to be an unload valve issue, the motor doesn't even really bog down much.
    It could also be that this is a maple that has stood for hundreds of years in someones yard, getting tougher and twisted by storms
    Hammy, T.Jeff Veal and Midwinter like this.
  3. brenndatomu
    Yeah, that's not right...bumping the bypass pressure up is exactly where I would go first too...
  4. metalcuttr
    metalcuttr
    western WA
    What brenndatomu said. You have got to have something wrong with your machine!
    Hammy, T.Jeff Veal and brenndatomu like this.
  5. stuckinthemuck
    stuckinthemuck
    For that horizontal splitter that splits in both directions, It looks like it takes more time to reposition the log to be split than it takes for a return stroke. Also seems that there isn’t an option to do a partial stroke then return back.. I’m a fan of vertical splitting.. on red oak, I generally need to run the wedge only a couple of inches into the wood... for some gnarly yard trees, on occasion, I need to run the wedge all the way through.. everything else falls somewhere in the middle.. so for my applications, I believe the two way splitter would slow me down. I agree that you should be able to split those rounds with the DHT splitter that you have. Curious to see what kind of mods you can make to improve the power...
  6. Rowerwet
    Rowerwet
    Seacoast NH/MA
    The trick is to only run the knife into the wood until the trailing edge is about an inch into the wood, by then a normal size round would be split enough to RIP it apart without much effort. This also means that you can drop the next round in place behind the knife and split it on the return stroke.
    This keeps the knife going about a foot each way in the middle of the travel range, only going full strokes for twisted stuff and knots.
    I did miss not having vertical with the big stuff I often harvest. That's why I sold the predator and bought the DHT.
    Hammy, T.Jeff Veal and stuckinthemuck like this.
  7. stuckinthemuck
    stuckinthemuck
    That all makes sense.. Thanks..
    Hammy and T.Jeff Veal like this.
  8. Rowerwet
    Rowerwet
    Seacoast NH/MA
    A couple guys in the church had some free time yesterday. So they attacked one of the four piles of rounds.
    We refilled the back of the last cord we burned
    Finished filling the extra tall rack
    And stacked almost a full cord on pallets between the rows.
    I laid the pallets down earlier, in case they got ahead of me in rack space , good thing I did. I was helping but tweaked my back pretty bad and had to drop out.
    Before I did my back in, I moved the fiberglass tonneau cover to make a shed for the splitter .
    We might get rain, or snow, or nothing at all, as once again this pathetic winter can't even do a snow storm worth anything around here, but at least the splitter will be covered from all the fail. 20190128_163339.jpg
    One pile down, and a dent in the second one, nice!
    Chazsbetterhalf, Hammy, Thor and 8 others like this.
  9. Rowerwet
    Rowerwet
    Seacoast NH/MA
    The pile that was here was almost two years old. I started it back when I was working that huge maple from a few years ago.
    My neighbor doesn't have a yard, instead he likes to sit and watch mine from his bench. (Nice deal, all that grass to enjoy, but no mowing) he's had a great view of the round pile for two summers, but now he can gaze on my wood racks instead :)
    And some of the lawn.
    I actually placed my racks to not block the view from his patio, or the awning he and his son made out back.
  10. Rowerwet
    Rowerwet
    Seacoast NH/MA
    The bigger reason is that it's easier on me. Even with picaroons and boards layed out beside the splitter foot, a 4 foot diameter maple round is a miserable amount of weight to shift around, half of one is about all I want to deal with
  11. Midwinter
    Chazsbetterhalf, Hammy, Thor and 6 others like this.
  12. T.Jeff Veal
    I know that feeling, didn't relirea they were that big. I had some white oak that size, set them on the foot of the splitter with the tractor. Noodle away plus you will have some good fire starter.
    Hammy and Rowerwet like this.
  13. Rowerwet
    Rowerwet
    Seacoast NH/MA
    A nice decorative layer of snow, perfect for Christmas day, too bad it's a month late and a foot short..
    Still haven't dusted my cross country skis off, may not get the chance at this point.
    Hopefully it's only a couple months until kayaking season starts! 20190130_043205.jpg on a good note, my splitter shed worked perfectly.
  14. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20190130_070351.jpg one of my planes getting a morning shower of de-ice fluid
    20190131_174054.jpg evening take off, flying south to fix a broken plane
    20190131_175214.jpg Wachusett mountain ski area lights
    20190131_185620.jpg approaching the Hudson river from the west
    20190131_190310.jpg lower Manhattan, flying over Jersey.
    20190131_190644.jpg short final for 22L at Newark Airport
    brenndatomu, Woodwidow, Hammy and 8 others like this.
  15. T.Jeff Veal
    Hammy, Thor and Rowerwet like this.
  16. Rowerwet
    Rowerwet
    Seacoast NH/MA
    20190201_122119.jpg my Friday, it got all the way up to 19 F 20190201_124855.jpg
    That round thing at the top was the problem, it's the oil pressure relief valve , it had a piece of debris stuck under it.
    Other than it being so cold that the oil was tacky and the O rings were stiff like plastic, the relief valve is held in place by a snap ring, it l didn't have the valve engaged correctly, the spring and washers would shoot out and most likely fall into the oil sump, requiring the engine to be sent out to the overhaul shop.
    No wonder I was sweating in the cold
    Success! So I got to drive home, and stop at Rockefeller senic overlook on the pallisades parkway
    And Piermont
    And the bridge is still lit up pink to celebrate the new child sacrifice law in NY :(
  17. Marvin
    Marvin
    Huntingdon, Pa
    I like the pics...
    I dont like this ^^^....meaning I wholeheartedly disagree with this law. But that is not a discussion for this place...
  18. Rowerwet
    Rowerwet
    Seacoast NH/MA
    Video of the landing at Newark from the right seat
  19. T.Jeff Veal
    That was cool.
    Thor, stuckinthemuck and Hammy like this.
  20. Hammy
    Hammy
    New Brunswick
    Rowerwet thanks for sharing your adventures as always. As for the splitter I am thinking there must be something wrong with it. I have no experience with them myself but have not heard a bad word about them. Hope you get it running like you want it soon.
