Give your old Harman Pellet Pro a Quick change!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Jan 21, 2019.
  1. don2222
    don2222
    Salem NH
    Hello
    The old Pellet Pro I or Pellet Pro II Harman stoves and VC Reliance pellet stoves have Exhaust or Combustion blowers that have 3 bolts to hold the motor on the exhaust housing. Therefore the only way to clean the blades and exhaust chamber is to remove the entire exhaust housing. This can be difficult. However I newer quick change housing can be cut and modified so a new Blower Harman, or any exhaust blower brand with a 6” round mounting hub can be easily installed!
    Don't forget to seal the new quick change housing to the inside of the Harman exhaust flange with High Temperature Silicone RTV, :)
    Pic 1 - Old Blower and housing
    Pic 2 - cutting the new quick change housing to fit. New housing has studs with nuts for easy exhaust blower installing and removal. :)
    See hole cut off with jig saw on right side
    Pic 3 - Mounting holes may also have to be elongated with a drill bit to align with holes
    Pic 4 & 5 - New 1.75 amp High Quality Exhaust Blower!
    Pic 6 & 7 - Harman Pellet Pro II
    In the Pines likes this.
  2. badbob
    badbob
    I have never worked on one of the old beasts,I like your conversion,and pictures.Thanks.
  3. ttdberg
    ttdberg Pellet Pig
    CT
    I’ve never seen a CB like that before. It must be an antique.
    don2222 likes this.
  4. don2222
    don2222
    Salem NH
    Since the CBs are not made anymore if you have one that works, it is worth some money$$$
    The older Pellet Pro I has a Control Panel that looks like the old Earth wood pellet stoves!
  5. don2222
    don2222
    Salem NH
