Ready for some cold weather...
Discussion in 'The Wood Pile' started by Pricey106, Jan 12, 2019.
How many fans do you currently have running to move heat?
Poll closed Apr 12, 2019.
  1. 1
    16 vote(s)
    51.6%
  2. 2
    6 vote(s)
    19.4%
  3. 3
    7 vote(s)
    22.6%
  4. 4 or more
    2 vote(s)
    6.5%
  1. Pricey106
    Pricey106
    Northeast PA
    Got a full stack by the stove, and the dog had the fire in his eyes. Love my pooch and dry firewood. I just wish the heat would travel throughout the whole house so the wife would stop whining....The only way I can get the whole house heated is load the stove up every 3 hours and run it full bore. Even then it takes about 24 hours to get everything to 68 degrees....I have 2 fans running and the stove fan going...time to start cutting some vents.
    Loon, Chvymn99, unclefess and 14 others like this.
  2. justdraftn
    justdraftn
    On the road
    2 Lopi fans.
    Marvin, Loon, Erik B and 12 others like this.
  3. TurboDiesel
    Nice pic! Stove blazin', pup and wood warming up by the stove! Perfect!:handshake:
  4. TurboDiesel
    Not a chance!
    :p
    Just joking, Sir.:handshake:
    Chvymn99, Pricey106, Hellcat and 13 others like this.
  5. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Zero aside from the furnace blower :whistle: Is that one or zero?
    ReelFaster, Chvymn99, Hellcat and 7 others like this.
  6. amateur cutter
    Run a fan full time over both shop heat ex changers & ceiling fan in the house. Keeps the air temp steady at 70 in shop & 75 in house. Weather man is threatening us now, we'll see. [​IMG]
  7. justdraftn
    justdraftn
    On the road
    …..uh-huh.....
  8. billb3
    none
    heat rises
    stove is downstairs
  9. JPDavis
    JPDavis
    Prescott, AZ
    4 fans. One on the stove that clicks on at 450 degrees. A ceiling fan in the living room to help draw the warm air in from the stove. One to help push the warm air upstairs and a ceiling fan upstairs in the office to help pull the air into it and the upstairs master bedroom. If you could see the layout of this home and what I have to do you'd cringe.
  10. Chris F
    Chris F
    Micksburg, Ontario
    The whole house will warm up quickly if that dry wood touching the hot stove starts burning :bug:
  11. Paul Booth
    Paul Booth
    MN
    That little stool is great!
  12. Ctwoodtick
    Ctwoodtick
    Southeast ct
    Ditto on the wood being too close.
  13. Eric VW
    Does it...? :sherlock:
    :salute:
  14. Backwoods Savage
    Wow!
    You did not add 0 to your poll. We can heat our house with no fans. But most times we do have a ceiling fan on low speed. Sometimes we forget. The only difference it makes is that without the ceiling fan, if I am sitting at the computer it does get a bit warm. Otherwise, the radiant heat we get from the soapstone stove really keeps the whole house warm.
    I might add that for those trying to move heat with a fan, don't make the mistake that I used to. Never try to move the warm air into the cool air; it just does not work. But if you move some cool air toward the warm air; bingo! With our old stove we had the problem of trying to keep the far rooms warm but we tried moving the warm air. Switch to using a small desktop fan on low speed, sitting on floor of hallway with air blowing toward the stove room and it was amazing how quickly the warm air got to the far rooms. Seems backwards but it works great.
  15. Pricey106
    Pricey106
    Northeast PA
    The temp of the wood never gets above 90 degrees...you can put your hand on that side of my stove. There is a thick airspace in the wall of the stove.
    Backwoods Savage and Loon like this.
  16. Pricey106
    Pricey106
    Northeast PA
    Carved that myself last year. First ever chainsaw carving...
    Backwoods Savage and Chvymn99 like this.
  17. Stoveburner38
    Stoveburner38
    Springfield,ohio
    I had seen and heard it's easier to move the cold aur to the hot air verse the other way.
  18. ReelFaster
    ReelFaster
    S.Jersey
    I voted one and counted my insert blower as one....
  19. Erik B
    Erik B
    Western Wisconsin
    I am like justdraftn I got two fans on my Lopi insert.
  20. Karvinkanuck
    Karvinkanuck
    It's been below freezing for some time , have an outdoor stove and windows open for air partially, only fan is if wind blows
