Re>stacking
Discussion in 'The Wood Pile' started by Stoveburner38, Jan 2, 2019.
  1. Stoveburner38
    Stoveburner38
    Springfield,ohio
    Got some work in the wood lot today got some skids moving all my stacks on to the skids. EventulaEv going to build a lil roof on them. IMG_20190102_115438.jpg IMG_20190102_115427.jpg IMG_20190102_115417.jpg IMG_20190102_115358.jpg 15464560216715158284399360985710.jpg
  2. ReelFaster
    ReelFaster
    S.Jersey
    Great looking racks!! Well done!
  3. Stoveburner38
    Stoveburner38
    Springfield,ohio
    Thanks. Just lil something im throwing together for the rest winter.
    This summer I have plans to build a better set up. Don't have much space so I need to be able to maximize my space.
    Sean, Woodsnwoods, Horkn and 10 others like this.
  4. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Thanks for sharing. Good work. I’m in the process of figuring where to store more farwood. Changing from utilizing a large commercial yard that a friend and I were able to store wood at because friends brother took a few cords last year.... I’ve got a good size lot for in town but it’s all fenced in and manicured. I think I can squeeze two or three rows deep along my 40’ deep barn/garage. Good thing is that is on the south side so should get good sun. Bad is the rain off the roof would come down on the wood.
    Your little racks with potential roofs are a good idea.
    JoeinO, Woodsnwoods, Horkn and 9 others like this.
  5. imwiley1
    imwiley1
    Wisconsin
    Looks like that will dry nicely. Keeping it off the ground is key. Top covered helps as well but it will be fine the way it is for now. Over the years I have changed my setup here and there to what works best for me as I'm sure a lot of us have.
  6. TurboDiesel
    Nice work, Stoveburner38 !
    Could i make a suggestion. Stack all the splits at the outside edge of the skid and fill in between with the shorts and unstackables:yes:
    you'll fit more wood in and it will be more stable:handshake: KIMG0389.jpg
    T.Jeff Veal, Marvin, Sean and 9 others like this.
  7. woody5506
    woody5506
    Upstate NY
    Turbo Diesel makes a good suggestion. Not only for stability, but if you're like me and get annoyed easily of seeing those ugly or especially short splits on your stacks, throwing them in the middle is the perfect solution to not see them again until the time comes to burn.
  8. TurboDiesel
    and the stacks are pretty-r
  9. Stoveburner38
    Stoveburner38
    Springfield,ohio
    IMG_20190106_125045.jpg IMG_20190106_125034.jpg IMG_20190106_125025.jpg IMG_20190106_120025.jpg IMG_20190106_120025.jpg
  10. Stoveburner38
    Stoveburner38
    Springfield,ohio
    Anyone can tell me ballpark figure how much wood I have curious.thanks
  11. bear 1998
    bear 1998
    S.C.Pa
    Maybe 1/4 or little better of a cord....
    Thats in your pickup....are you talkin...altogether??
  12. Horkn
    It's easy when it's stacked. Just take measurements, and put them in the cord calculator. Do that for each stack.
  13. Stoveburner38
    Stoveburner38
    Springfield,ohio
    Talking altogether
    T.Jeff Veal and Woodsnwoods like this.
