Clutch time
Discussion in 'The Wood Pile' started by Buffalo Plaid, Dec 31, 2018.
  1. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    Ive been cutting lots of small dead pines for use as evaporator fuel making maple syrup. I came across an oak that was begging to be felled, so I obliged. Perfect hinge and it fell exactly were I intended. Went to cut the stump down, finished the cut, threw the chain and left the clutch with several broken and missing pieces. Looks like I'm done cutting for the year. Happ New Year. 20181231_133924.jpg 20181231_133933.jpg
    bang, T.Jeff Veal, Marvin and 16 others like this.
  2. papadave
    It ain't ovah til it's ovah.:saw: You still have time.
  3. Mag Craft
    It does like look like it got pretty hot. Get some new springs for it and you should be ready to go again unless there is something else I do not see in the pics that is bad. Make sure to grease the bearing while you have it apart. All that heat probably dried it out.
  4. Slocum
    Slocum
    North Central Indiana
    X2. Thanks baby saw some heat.
  5. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    I'm not sure if the bearing failed first or something else but it's disintegrated. Among the missing and broken pieces are the washer and clip that holds every thing together, a couple of shoe retainers, a spring and two of the clips that sit on top of the springs (that's the two chunks sitting next to the sprocket in the picture.)
  6. Midwinter
    Just have one saw? (Me too!)
  7. Mag Craft
    Sounds like a new clutch might be in order.
  8. MikeInMa
    Well.... it is a new year.
    :cool:
  9. Backwoods Savage
    Nasty... But at least you got the tree down.
  10. billb3
    Well if this happened on 31 Dec and you didn't have spare parts I guess you would be done for the year.
  11. chainsawsoldier
    chainsawsoldier
    NE Kansas
    Is that a 290? I have a decent clutch assembly I could send you for only cost of postage. I had one break at the crank behind the clutch assembly . It now works great as a Halloween prop(we help out on a local fundraiser each year, and I enjoy the reactions from people on the hayride that go by)
  12. Mag Craft
    Can not beat that.
    amateur cutter and T.Jeff Veal like this.
  13. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    I've got three all of them now in various states of disassembly :tears:
  14. Buffalo Plaid
    Buffalo Plaid
    Pepperell, MA
    No it's a 271. I appreciate the offer though.
  15. coreboy83
    coreboy83
    NW of Twin-Cities
    time for a rim sprocket
