fuel and mix ratios, what's yours?
Discussion in 'The Wood Pile' started by Jim Barry, Dec 31, 2018.
  1. bushpilot
    bushpilot
    Eastern Washington
    I buy the cheap "Pro-Mix" oil and mix it according to the label, which works out to 50:1 (but they say that it is good for all ratios). It goes into all my 2 strokes, regardless of the recommended mix. I mix it with E-Free gas.
    So I guess I go cheap on the oil and expensive(ish) on the gas. I have never had a problem with this combination in anything I run. I would run cheap gas as well, but ethanol has caused me problems in small equipment in the past.
    I run cheap bar oil as well ...
  2. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I run E free fuel, somewhere around 45:1
  3. mr.finn
    mr.finn
    Mass
    I run 50:1 using Shindiawa Red Armor oil and 93 Ethanol gas. Every other mixing I will go 45:1. Never had an issue. May start looking into e free gas because I don't burn as much mix as I used to
  4. moresnow
    moresnow
    40:1 with non-eth. Never a problem. Yet!
  5. TurboDiesel
    I run Stihl's oil at 40:1 in 100LL Avgas in all the saws, weedeater and backpack.
    (guaranteed 100 octane but tests at 108 and, of course, its non-e)
    I'm planning to switch oil once i run out of stihl oil.
  6. moresnow
    moresnow
    Mmmmmmmmm. Avgas! Picturing myself on the um... Tarmac. Filling my giant 2.5 gal.o_O saw gas can with high test! Good idea! The guys at our little airport should get a chuckle!
  7. komatsuvarna
    komatsuvarna
    87 E-free with schaeffer's 9000 synthetic at 32:1.
  8. Chris F
    Chris F
    Micksburg, Ontario
    Jonsered calls for 50:1 but the dealer advised 45:1 so 45:1 it is.
  9. TurboDiesel
    our airport has a 5 gallon minimum.:handshake:
    i use one of these then transfer to my 2 gallon No-Spill jugs as needed
  10. M2theB
    M2theB
    Central Massachusetts
    2F6485DF-B196-463B-9BF6-CA743B1318BA.jpeg 50:1
    Nearest e free gas station is a two hour drive for me. I had been buying sporadically in gallon cans, @25/whack.
    Just last week I went to the local Marina Shop and picked up the 5 gallon can for $75. Still not cheap, but 40% off what I had been paying, plus the cost of the mix, which is the Husqvarna xp. 1 bottle to 1 gallon; 50:1.
    94 Octane
    Marvin, leoht, amateur cutter and 4 others like this.
  11. bushpilot
    bushpilot
    Eastern Washington
    I would never run a saw on Avgas. IMO, Avgas is poorly suited for pretty much anything, except when required for certain aircraft. Even most aircraft can be run on e-free mogas, and run cleaner with it.
    Avgas has a lot of lead, even 100LL (low lead). I would not want to be breathing in that lead. The high octane of Avgas is of no value in engines that do not need it. (Octane does not add power.) The saws that need it would only be those that have been modded to have very high compression ratios, if those even.
  12. Backwoods Savage
    Used to always run 40:1 but lately 50:1.
    leoht, amateur cutter, M2theB and 2 others like this.
  13. moresnow
    moresnow
    Completely agree. High compression takes advantage of high octane fuel. 87 proof engines get mostly zero out of it. The operator however... Thinks it runs better (this is HUGE)! And oooohhh the smell:thumbs: A continuing argument with sleds, bikes, saws etc. forever. Kinda funny.
    leoht, brenndatomu, M2theB and 2 others like this.
  14. In the Pines
    In the Pines
    32-1 93 octane in all my 2 cycle. with some marvels mystery oil added.
    leoht, M2theB, Chvymn99 and 2 others like this.
  15. Reloader
    Reloader
    NW Oregon
    32:1 non-ethanol
    Sent from my iPad using Tapatalk
    In the Pines, leoht, M2theB and 2 others like this.
  16. metalcuttr
    metalcuttr
    western WA
    50-1, Stihl oil and e-zero gas. Never have had any problems. If I add more oil, the spark arrester screen in my Stihl blower loads up with soot!
  17. Will C
    Will C
    New York
    E-free gas, Stihl synthetic oil, and Sea-Foam is my mix at 50:1.
    In the Pines, M2theB and leoht like this.
  18. JCMC
    JCMC
    Just outside of Shushan, NY
    40:1 91 octane e-free gas synthetic 2 cycle oil and 1/4 oz. LC-20.
    In the Pines and leoht like this.
