fuel and mix ratios, what's yours?
Discussion in 'The Wood Pile' started by Jim Barry, Dec 31, 2018.
  1. Jim Barry
    Jim Barry
    Loch Katrine, Nova Scotia
    For those of you that mix your own oil and gas, what ratio are you using? 40:1, 50:1, 100:1 ? Does it depend on what type saw you are using? Does it depend on how long you are going to be running the saw on a given day?
  2. Erik B
    Erik B
    Western Wisconsin
    I am running 50:1 in all my 2 stroke engines.
  3. Canadian border VT
    I run 40 to 1 cause I rather have a little to much smoke than not enough oil on things..
  4. Hatchetdancer
    Hatchetdancer
    45:1 in my Dolmar.
    Saw shop man said to run it a little rich due to it being made to run 14200 rpm
  5. saskwoodburner
    saskwoodburner
    I'm 40:1 for my little chainsaw. Doesn't mean I'm right though, it's just what I do.:saw:
  6. Farmchuck
    Farmchuck
    Nepa
    40:1 non ethanol 90 octane & amsoil Sabre. If it makes past 4 weeks it goes in the John Deere B & I mix a new batch.
  7. imwiley1
    imwiley1
    Wisconsin
  8. Jim Barry
    Jim Barry
    I've been running 40:1 as well. Its just I've been questioning that since I burned up a Husq 353 the other day.
  9. MightyWhitey
    MightyWhitey
    40:1 in my 40+ year old McCullock 610 as it's my only chainsaw. All that bad boy does is cut wood....................very well.
  10. papadave
    About 45:1. Been a while since I mixed up a batch.....just about due for more.
  11. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    50:1 cuse the book says so and I'm not educated enough in that field to try anything different. Also E-free fuel.
  12. bear 1998
    bear 1998
    S.C.Pa
    I run 40:1 in all my 2 stroke engines...e free gas.....
  13. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Oil goes in the small hole. Gas goes into the big one. It must be a variable ratio that arctic cat has engineered so it runs like mosquitoe fogger (8:1 or worse) at startup and then bleeds down to 60:1... Nervous it's going to explode ...after warm up. It's like magic or something...
  14. amateur cutter
    32:1 Dolmar 2 stroke oil & 89 Octane Rec gas. Easy math & I haven't smoked a 2 stroke on that mix in 35yrs.
  15. Chvymn99
    I run 32:1 in all my ported saws... and so my weed eater gets the same thing too...
  16. blacktail
    blacktail
    PNW
    50:1 for my saw and blower. That what the manufacturers say and the Stihl bottles are sized for 1 gallon of gas. 50:1 in my Evinrude too, even though they tried to recommend 100:1 for that year.
  17. T.Jeff Veal
    Close to 50:1in all our Stihl equipment. I try to put just a little less than 1gal on gas in the can. 93 octane, going to start non-E as soon as I finish up what we have mixed.
  18. brenndatomu
    32:1...still nursing an old jug of Yamalube 2...run 40:1 when using synthetic.
  19. leoht
    leoht
    Victoria. Australia. Earth.
    I run 25:1 on 95 octane no ethanol as recommended by my friend who owns the local Husqvarna dealership, due to our hot and dry climate I think the extra oil helps. The manuals for Husqvarna and Stihl both Say 50:1 but I think that is more for pollution requirements rather than engine longevity.
  20. Horkn
    My buddy runs his sabre at much leaner than that. I think he says 80:1. I don't trust that and user either sabre or Lucas at 50:1 . I run e10 87 octane because all of my saws are designed to run e10.
