Harman Advance with pre 2004 Burn Pot burned Tip of Auger
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Dec 21, 2018.
  1. don2222
    don2222
    Salem NH
    Hi
    Anyone seen this?
    The fire was roaring out of the back on both sides of the old Burn pot. First time I have see this!
    The thin OEM gasket had very little left to it!
    I updated to the new fluted Burn pot and thru in a new auger with a good gasket!
    See pics
    badbob likes this.
  2. badbob
    badbob
    wow,nice pictures.I have heard of this,but,first pictures I have ever seen.Thanks,Don.
  3. Lousyweather
    Lousyweather
    yes, Ive seen it....quite a bit! Fortunately, easy fix....just replace the auger. That auger is nowhere near the worst Ive seen though......Seen them with half the flights gone, and the center spindle being a point. Far as I can tell, this happens when the owner decides that they will save big bucks on lowering the feed rate to, like, 1, instead of 4 or more....basically misunderstanding the machinations of the feed rate. Dont run your feed rate at one grasshoppa, it will only cost you money. It doesn't run more efficiently at 1.......
  4. ivanhoe
    ivanhoe
    Northern Ontario
    They should of not have a #1 or discreetly make it a #2, engineers:picard:
    bogieb and Lousyweather like this.
  5. Lousyweather
    Lousyweather
    probably right, but 1 and 2 are on the way to TEST mode, so, there they are. Same argument......why have a car that can go over 65?
    ivanhoe likes this.
  6. don2222
    don2222
    Salem NH
    Here is a much better picture of the flames on the side of the old Burn Pot.
    ivanhoe, bogieb and badbob like this.
  7. badbob
    badbob
    Nice pictures,Don,thanks.You seem to run into the weird problems,and handle them well.
    ivanhoe, imacman and bogieb like this.
  8. bogieb
    :hair:
    ivanhoe, don2222 and imacman like this.
  9. Harman Lover 007
    Harman Lover 007
    Eastern Mass
    The overwhelming majority of Harman owners totally misunderstand the feed rate function.
    Lousyweather and ivanhoe like this.
  10. don2222
    don2222
    Salem NH
    That is the Maximum Feed Rate setting, because on Room Temperature, the Feed Rate automatically varies to maintain the desired room temperature that is set on the temperature dial. :)
    Lousyweather likes this.
  11. Harman Lover 007
    Harman Lover 007
    Eastern Mass
    Yes Don. I completely understand it. My point was that most (other than those of us here) don’t.
    imacman, Lousyweather and don2222 like this.
  12. Lousyweather
    Lousyweather
    Probably the most misunderstood issue with Harmans! Now with the TC units, pretty much a nonissue.
