Service ramps
Discussion in 'The DIY Room' started by Screwloose, Dec 18, 2018.
  1. Screwloose
    After the "pucker factor" subsides these are kinda nice. Retired mechanic had them listed on Craigslist where i stumbled upon them an they were reasonable.
    Maina, HDRock, Horkn and 9 others like this.
  2. Eric VW
    No good.:confused:
    Pack them up and send them here.... I will deal with them accordingly.:yes:
    JK, them’s pretty sweet!:salute:
    Maina, Horkn, Chvymn99 and 5 others like this.
  3. Screwloose
    If you ever want a set search "display ramps" several listed by me. Things are pretty strong. Heavy to. In the picture I used the jack stands for peace of mind.
    Maina, In the Pines, Chvymn99 and 3 others like this.
  4. don2222
    don2222
    Salem NH
    Wow, looks like it would be a little scary to drive up on the ramp!
    Are those access letters really steep?
    Horkn, Chvymn99, Screwloose and 2 others like this.
  5. eatonpcat
    There is the pucker factor that he mentioned. Looks like the ramps could be less steep with a smaller vehicle and delete the bottle jacks maybe??
    Horkn, Chvymn99 and Screwloose like this.
  6. Screwloose
    Thor, Horkn, Chvymn99 and 1 other person like this.
  7. Screwloose
    The jack stands turned out to be a totally unnecessary precaution. The ramps teeter totter once the vehicle is past the halfway point.
    Maina, Thor, Horkn and 2 others like this.
  8. Screwloose
    The ramps have a roller on the bottom and they are hinged.
  9. eatonpcat
    I love them, just not sure I have the GNads to mount them suckers!!
  10. Screwloose
    Full disclosure....... I had my son drive it up.
    Stephiedoll, Maina, Thor and 4 others like this.
  11. Chvymn99
    Those are pretty slick... never seen such a thing....
    Horkn, Screwloose and eatonpcat like this.
  12. eatonpcat
    Hahaha...Smart man!! I see no Srewloose here!
  13. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I used to work under an old single post lift years ago, and it looked less sketchy than that thing! My lift would jump up the last 6" if you didnt back off the lever too.
    Maina, In the Pines and Screwloose like this.
  14. Screwloose
    They are extremely solid. I should have charged admission for the amount of scrutiny that they have received. They don't move and believe me a lot of people have tried. It's made from 3"x3"x5/16" angle with nice wet in welds. Takes two people to move each half.
    Maina, Thor, Chvymn99 and 3 others like this.
  15. Creekin
    Creekin
    Manitoba
    I don't see whats so sketchy about those ramps, would use those all day long
    Look well made
    Used alot of hoists that were waaaaay scarier than that, would just make sure they're safe when the car is on them
    Ever see some of those cheap stamped steel ramps ypu can buy at any hardware store? Those are sketchy!!
    Maina, eatonpcat, Chvymn99 and 2 others like this.
  16. Horkn
    I see you are enjoying our not so frigid "winter" we are having. ;)
    Did you get what you needed done? The weather doesn't look so nice later tonight and into all of tomorrow.
  17. Screwloose
    I was just doing some corrosion prevention on the x cop bourbon.
    Hot pressure wash using Dawn. Compressed air dry out. Nice coating of the complete underneath with my special sauce.
    Sauce recipe is ..... CRC sp 4oo (bulk 5 gallon not aerosol) with 3oz of Kroil per gallon plus some thinning with mineral spirits. Spraying everything right from the can with a shuts gun at 135 psi. Getting it in every nook and cranny. For a couple of days it smells exactly like a new box of crayons. Wish the weather would hold out as I'd like to do 3 possibly 4 more vehicles. Used 1 3/4 gallons of sauce on a 3/4 ton suburban.
    Maina, Chaz, Thor and 3 others like this.
  18. Thor
    Thor
    Genoa City,Wi
    I'm only 15 minutes away if you need another vehicle to test it on.:D
    eatonpcat, Maina, Chvymn99 and 3 others like this.
  19. Screwloose
    I'm sure we can work something out.
    Thor, Maina, Chvymn99 and 1 other person like this.
