Closed Frame Exhaust Blower with loose case - Magnum BC-AC
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Dec 7, 2018.
  1. don2222
    don2222
    Salem NH
    Hello
    Has anyone seen this issue???
    In this case we replaced this exhaust blower with a heavy duty high quality 1.75 amp exhaust blower with an impeller with tall petals and no base plate to eliminate dragon startup and it will never have a loose case because the larger magnetic plates will not fit in the smaller black case!!!
    Enjoy
    Vid 1 of 3
    Vid 2 of 3
    Vid 3 of 3
    Pic 1 - old 1.6 amp closed frame blower
    Pic 2 - new 1.75 open frame blower
    ChandlerR likes this.
  2. heat seeker
    heat seeker
    Connecticut North Central
    I have the same situation with the aftermarket fan in my St Croix. It was unbearable. I balanced the fan by removing metal on the heavy side, so now there is very little vibration. My situation now is that it is a bit noisy on startup, when the motor is cold, but quiets right down when it gets warm. The aluminum expands to fit the steel case fairly tightly, so with the reduced vibration, it makes no unnecessary noise. I can live with it now, quite easily.
    badbob, jtakeman and imacman like this.
  3. badbob
    badbob
    Don is right,about recrimping the motor being possibly a temporary fix.Imbalance in the impeller,from the factory,or from debris buildup,can loosen it up again.
    imacman likes this.
  4. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    OH MY GAWD...I have never heard one that loud...sounds like a rock crusher at full load..
    don2222 and badbob like this.
  5. don2222
    don2222
    Salem NH
    Yes and that case was very loose!!
    badbob likes this.
  6. ivanhoe
    ivanhoe
    Northern Ontario
    That's exactly what happened on the Fahrenheit furnace. The crimps loosened up, why why why I say to myself? I'm gonna epoxy it or mcgiver something up :whistle:
    Can't waste a good motor :doh:
    badbob and imacman like this.
  7. badbob
    badbob
    If it is steel,crimp back together,and put a few spot welds on it.
    ivanhoe and imacman like this.
  8. ivanhoe
    ivanhoe
    Northern Ontario
    Thx for the tip, sound easy to do:yes:
  9. krooser
    krooser
    Waupaca, WI
    Good job Don...
    ivanhoe likes this.
  10. don2222
    don2222
    Salem NH
    Hello
    Just got the chance to weld the black case to the frame!
    Just had to scrape off some of the black paint to get a better weld!
    No more warbles!!
    badbob likes this.
