  1. badbob
    badbob
    Laid in the snow,swapped out one of the fuel tanks on plow truck(79 k20),rusty mess.But,was 45,60% sun,and zero wind,a great day to do it.Switching valve and switch even work,after not being used for 10 years or more.
  2. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Got more work done on the shell crusher today....
    Found some leftovers in the shop and decided to re-purpose them.
    A 10 inch aluminum channel was perfect.
  3. Earl764
    Earl764
    CT
    Snowy, you’re my DIY hero.
  4. badbob
    badbob
    Gee,Snowy,you get all the inside work,and I am stuck up here without a garage,so jelly.But,your work is so very nice.
  5. Luneyburg
    Luneyburg
    Hills of Central Mass
    Tomorrow is the day I give notice after not having done so in 39 years, hence the reason I am still awake.
    One of the owners came by tonight and sealed the deal should be an interesting day tomorrow, hopefully the owner of Consigli will not be there tomorrow but you never know and the #2 is there ever week and he is the one I answer to directly and will give notice to.
    Wish me luck !
    Hope all are well.
  6. badbob
    badbob
    Best of luck!!!!
  7. ivanhoe
    ivanhoe
    Northern Ontario
    Good luck Luney :cheers:
    CleanFire, Luneyburg, imacman and 6 others like this.
  8. Rich250
    Rich250
    Berks County PA.
    ditto
    CleanFire, Luneyburg, imacman and 7 others like this.
  9. bogieb
    Boss was okay. I'm unsure if the big boss-lady or COO know yet. I told them I was going to a company that can help me move my way back to where family lives because they have satellite locations in the area that I could slide into sometime down the road - what can they possibly say to that when that is something they can't do?
  10. bogieb
    Best of luck!
    CleanFire, Luneyburg, Rich250 and 6 others like this.
  11. jtakeman
    Hope all goes dandy sir!! :)
    :cheers:
  12. slvrblkk
    slvrblkk
    Northampton, PA
    :popcorn:
  13. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Thanks troops for the THUMBS UP
    This project is a far cry from high tech, or a close tolerance gig, but actually is more in line with a "Rube Goldberg" :yes:
    This is one of those projects that made having the lathe, the mill and even the 18 volt Ryobi tools a real asset..
    The ancient Formost band saw was put to use. (Saw is just like the small horizontals the HF sells) My son in law borrowed the Jet band saw and I had a project going, so I scared up this old filthy Foremost off Craigs list for $50.
    Definitely no tight tolerances on this gig though.... As long as the drill motor is in line with little grain mill shaft and the coupling is not binding....WE ARE GOLDEN...
    The mill should be here today at the Post office...
    Once that is here it's off to the rodeo we go.
    I will post more pics and info as I have it to show...
  14. imacman
    imacman
    Denver, NC
    Fingers crossed for ya!
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  16. slvrblkk
    slvrblkk
    Northampton, PA
  17. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    How did it go today?
  18. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Got the little mill today..... and it looks great.
    I ran some shells through it with the hand crank and the beast does a sweet job
    Got the little critter outta da box...SOME ASSEMBLY REQUIRED:yes:
    With things very much in a state of flux as far as what the shell plant is going to do I decided that maybe more barrels are a good idea.
    We stopped by the Jelly plant here in town...Yessssssssssssssssssssss...they had a buttload of barrels..
    Free is a very good price.
    Got 20 on the trailer and 4 in the truck :thumbs:
    If the plant does not or can not get the shells crushed more, then we are set now for more high volume low weight storage...
  19. bogieb
    No answer from Luneyburg yet. Hmm, maybe someone should take a ride to Helvard and see if they have stashed a body somewhere?
    CleanFire, subsailor, imacman and 7 others like this.
  20. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Extremely ashy, 1.5 bags and I have to clean the stove or it starts huffing almost violently. To be honest they do put out good heat and the glass is fairly clean.
