550XP Auto Tune Diagnostic Reults
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Nov 29, 2018.
  1. M2theB
    M2theB
    Central Massachusetts
    2DD9DD60-6798-45D1-A6B7-6AF6D0D8C5BC.jpeg 2A693BED-6016-47F3-A91F-DDF64A7B2D68.jpeg 58BF9C81-A4DC-458D-A32F-E26C3DAD64FA.jpeg B5B987B7-1F1B-46FA-9FBC-540D9FCA4D74.jpeg D465F0E2-B853-477A-80EC-481CCDA81598.jpeg I have a 550XP I bought new about a year ago and it’s by far the best saw I own pound for pound.
    I got this guy and two others, a 235 and a 450, on CL deal.
    Compression on this one was next to nihl! But from outside it looked pretty good.
    So I brought it to a local shop that has ( hard to find one equipped) the auto tune diagnostic tool, hand written record above.
    Two questions;
    1) what would you do in light of the diagnosis
    And
    2) what should an Auto Tune diagnosis cost?
  2. GrJfer
    GrJfer
    The Woods of Arkansas
    I'd start by pulling the muffler and see if the pistion is scored. Do a leak test. As for cost on a diagnostic print out price mine was $30.
  3. The Wood Wolverine
    I'd do a pressure/vac test. If it doesn't hold pressure I get out my trusty soapy water spray bottle.
    Hammy, Nixon, amateur cutter and 3 others like this.
  4. M2theB
    M2theB
    Yeah, I thought that would be the number. This shop, pretty sure, just eyeballed it. They just sent the tech to school the week before. I paid more than 30. No print out, but a hand written record because they’re not set up for it yet.
    And I’ll pull the muffler for sure, but I’m pulling the cylinder to see what’s going on. This thing has compression like it has no piston ring.
  5. RCBS
  6. JCMC
    JCMC
    Just outside of Shushan, NY
    :popcorn:x2 :pete: keep us posted! M2theB
  7. Hammy
    Hammy
    New Brunswick
    Nice score. This will be I teresti g to see how it pans out. Good luck!
  8. M2theB
    M2theB
    Thanks. I got all three of those saws for the same price as the diagnostic.
    I think I’m going to fill it with non ethanol fuel and flush it via crank and primer, dump and flush again, replace the plastic and p/c.
    Watching and reading on the tools to leak check this puppy and the evidence leaning toward bad fuel, and it smells bad in the tank and it only has 22 hours on it, I think it’s a reasonable approach. Standby for more.
    amateur cutter, Ronaldo, Chaz and 2 others like this.
  9. M2theB
    M2theB
    667F73AE-9C21-434C-9DF4-C9278A0396AB.jpeg B0FAC530-65C5-495B-B005-F8C3B84D6EE3.jpeg F6F4492A-4E7F-4DD9-B11D-C355B2CC965E.jpeg 06F1BAFB-AFC2-4A29-B85E-A186011E1FCF.jpeg
    It’s not good, but what was expected.
    What I didn’t expect was a missing circlip on the starter side.
    I’m thinking that came out and started the downfall of this one
    RCBS, Rope, Hammy and 2 others like this.
  10. M2theB
    M2theB
    Aside from the obvious insult, the saw is pretty clean.
    But something is bothering me about it.
    It still smells a little. And the 450 part saw that came with it stank. Like cat pizz or something.
    There’s a story behind the three saws that the previous owner wasn’t sharing.
    Anyway, OEM p/c kit is on the bench and fuel and purge lines were ordered today from local shop.
    37E53F7A-E5EE-44F9-9485-2FCC6323AD3A.jpeg DBC70332-45F8-4BFF-B560-6CBB6D915700.jpeg BF422221-82A9-47D8-BC81-59A57F3AD3D9.jpeg
    RCBS, Rope, Hammy and 3 others like this.
  11. dall
    dall
    West Virginia
    scoring all the way around piston is straight gas
    RCBS, huskihl, Hammy and 3 others like this.
  12. M2theB
    M2theB
    Intake side.
    What do think with this info?
  13. dall
    dall
    West Virginia
    when completely around scoring it is straight gas that caused the failure
    if it was on just one side it would be lean seized but with these new mtronic auto tune saws kinda hard to do that
  14. M2theB
    M2theB
    I’m gonna play the odds.
    Going back to the diagnosis.
    Tank smelled bad, so bad gas. And damage to the p/c ( there’s a liberated circlip).
    Not much run time so seals aren’t likely.
    I hope it’s a good bet.
    Hammy and amateur cutter like this.
  15. Creekin
    Creekin
    Manitoba
    Maybe original owner was too embarrassed to say he straight gassed it?
  16. The Wood Wolverine
    Sounds plausible. Good call dall
    amateur cutter, M2theB and Hammy like this.
  17. dall
    dall
    West Virginia
    IMG_4475.JPG IMG_4476.JPG IMG_4478.JPG IMG_4479.JPG IMG_4480.JPG IMG_4481.JPG
    First tank straight gas saw I picked up
  18. M2theB
    M2theB
    Looks like there was a path across the bottom of the cylinder and top of the gasket for air to pass. Follow the schmootz all the way across the surface. A06B0620-48DB-4E57-869E-EAA3433F3C72.jpeg 3468DE69-988C-4AA1-829B-2EB25D5FA4A8.jpeg
    And looking harder under the muffler, the greasy dust layer is pretty defined.
    amateur cutter and Hammy like this.
  19. M2theB
    M2theB
    What’s interesting is there is no hold down bolts in that area.
    Only the muffler outboard of that area would try to help hold that down.
    And very interesting is that this saw had a missing muffler hold down bolt.
    Hmmmmm!
  20. The Wood Wolverine
    I'm not following about the potential for an air leak. Are you implying the bottom of the cylinder is not flat? Have a straight edge to show this?
    amateur cutter, Hammy and M2theB like this.
