D009 bar- what ALL saws will it work on
Discussion in 'Chainsaws and Power Equipment' started by tamarack, Nov 25, 2018.
  1. tamarack
    tamarack
    paulina oregon
    I already know the d009 is large mount husky- jonsered, but do any our resident experts know if these will work with the pioneers or older dolmars?
    amateur cutter likes this.
  2. huskihl
    huskihl
    It works on some new Dolmars. 64xx-79xx series. A little loose on larger Echos, but works.
    Which older Dolmars are you thinking?
    tamarack and amateur cutter like this.
  3. tamarack
    tamarack
    paulina oregon
    Mostly thinking of pioneer p45 or poulan pro 455 because I have one. I believe the d009 will work on this saw with a modified stud on the chain tensioner. Needs to be round not square.. I dontd have any old dolmars but I do like them and would love to find a 120 super or a 143 in running condition.
    amateur cutter and huskihl like this.
  4. huskihl
    huskihl
    This should help. Find the saw you're curious about and scroll down. The bar mount pattern for most saws is listed. There is also a bar pattern section to compare one to another to check compatibility with redneck engineering
    Chain Saw Collectors Corner Home
  5. Jnb
    Jnb
    New Brunswick
    I had a f55 farmer ( partner 55)with that bar mount, it was a good old saw. I now have a 16" bar that I had for it modified to fit my 261 stihl, just widened the stud slot to 12.1 mm I believe, and run a 58 link 3/8 chain.
    tamarack likes this.
  6. Reloader
    Reloader
    NW Oregon
    Works on the larger Shindaiwa saws.
    Sent from my iPad using Tapatalk
  7. thistle
    thistle
    Polk/Guthrie Counties,IA
    fits the p50/51/52 & p60/61/62 also
  8. Nixon
    Nixon
    West Sunbury,Pa .
    I know it’ll work with Dolmar 6400- 7910 . Not sure of the olderdolmars . Go to bailey’s ,and use their bar selector guide . It’ll tell you what you need to know .
    Fifelaker and tamarack like this.
  9. tamarack
    tamarack
    paulina oregon
    I don't get along well with baileys website. I think it is intended for PC not smartphone. Good to know that the D009 works on newer dolmars.
  10. Nixon
    Nixon
    West Sunbury,Pa .
    Yeah , they “ improved “ the site . Makes it harder to use . . .
    You can also try www.oregonproducts .com . Type in the make and model of the saw you have ,and it will give you your options for bars . It looks like quite a few earlier Dolmars used the k095 type mount .
    tamarack and Fifelaker like this.
