Saving rusted solid saw chain
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Nov 11, 2018.
  1. Screwloose
    IMG_20181110_170938480.jpg IMG_20181110_171239237.jpg So looking for suggestions on saving these 3 chains. They are Mall scratchers and I was told that there unused. So electrolysis, phosphoric, beet pulp........ what's your go to method ?
    Acres site says my saws longest bar was 144" so my plan is to fabricate a bar and use the 3 chains to make 1 long one.
    Also if anyone knows of a 8',10' or 12' Mall bar that's available......
    As always thanks for any opinions
    Boogeyman, Marvin, thistle and 5 others like this.
  2. OhioStihl
    OhioStihl
    Southern Ohio
    That’s a whole lot of chain. Well above my knowledge and pay grade. I hope you can save them for your project
  3. huskihl
    huskihl
    Electrolysis may work. Seems like WeldrDave was one who'd used it. Or if not, maybe he'll know who.
    Soaking in muriatic acid will definitely take it to bare metal as well, and they'd need to be oiled immediately afterward
  4. WeldrDave
    Yup, you can make a simple electrolysis tank and it'll clean them up. It'll take a day or so. You tubes got lots of ways to make one. If you have a simple 10amp battery charger, you can make a electrolysis tank. Washing soda from the store and your good to go! :yes:
  5. Mwalsh9152
    Mwalsh9152
    Pelham NH
    White vinegar will do the trick too
  6. TurboDiesel
    "Manual" charger may be a better description:handshake:
  7. Screwloose
    I have one charger that if put on a dead battery won't do anything. I flash it with a DeWalt battery and off it goes.
    amateur cutter likes this.
  8. Screwloose
    Thanks for the replies ! Normally I glass blast but a crunchy sounding chain I don't want. Nervous about hydrochloric (muriatic) acid because of the chance that the chloride might aggressively attack the carbon in the tooth. I have 30+ gallons of phosphoric acid but I'm concerned about what will happen if I have them black oxided later. Never tried vinegar.... yet. Interested in the electrolysis method, also something I've never tried.
    huskihl and amateur cutter like this.
  9. Screwloose
    Also I should say I don't intend to actually run the fabricated bar or this chain. My wife said that I can hang ONE chainsaw from our beam ceiling in the stove room. Go big or go home.
    Chaz, blacksmith, eatonpcat and 6 others like this.
  10. amateur cutter
    I have not tried electrolysis either, but I've had very good success with auto trans fluid on rusty gummy chains. 2day soak usually.
    Shame you can't find a bigger saw to put on display.:picard::eek::jaw:
    Screwloose, huskihl and WeldrDave like this.
  11. WeldrDave
    Good point!!!!!! :yes::emb: Yes, an automatic will cycle and do nothing!
    Chaz, Screwloose, huskihl and 2 others like this.
  12. WeldrDave
    Not hard at all. Get ya some junk steel, old rebar or anything like that and a tupperware tub and have fun.
  13. WeldrDave
    Heres my simple set up, what you don't see is "washing soda". Add 1 cup to a tub this size. Heres some pan pic DSCN1945.JPG DSCN1953.JPG DSCN1946.JPG DSCN1518.JPG DSCN1519.JPG DSCN1605.JPG s I did some before and some fresh out of the electrolysis.
    Chaz, woody5506, eatonpcat and 7 others like this.
  14. Breechlock1
    Breechlock1
    Soak in 50% kerosene 25% AT Fluid and 25% brake fluid. Pull em out in a month and theyllt be gtg
  15. WeldrDave
    That's a close mix to my own gun bore cleaning fluid! o_O
  16. Screwloose
    WeldrDaves setup is what I will try. Ebayed a nos manual 10 amp charger last night. Dang I tossed a lot of them in the past..... Need to come up with a tank, the chain that takes the most area is 52"x10". Actually a little excited to try this out.
  17. WeldrDave
    My charger is "both" manual/auto. I just set it to manual mode. The tank is from home depot, it's just a heavy type storage container. Get ya some junk metal and go to town. "Be Patient"!!! It'll happen. I leave my stuff in at least two days sometimes or more if it's real bad.
  18. Screwloose
    Only charger I had with a manual setting started at 30 amps. Plenty of metal available here. I can be pretty patient..... well usually. I'll post some pics when I get going. Thanks
    amateur cutter, Chaz and WeldrDave like this.
  19. WeldrDave
    I have a few chargers, 30 amp is no big deal, you can use that just check it about every 6 hours. My small 10/2 amp I actually found at a garage sale cheap. Look at flea markets and if you have a Tractor supply close they have good sales. Maybe walmart...
    amateur cutter, Chaz and Screwloose like this.
  20. Screwloose
    Does the current capacity of the charger change the aggressiveness of the action ? I could hook it to my syncrowave ..... I wonder what would happen on pulse.
