Five year old ash log
Discussion in 'The Wood Pile' started by BigPapi, Nov 11, 2018.
  1. BigPapi
    BigPapi
    The hills of Western MA
    Inspired by the thread "Firewood Longevity" I decided to process an ash log that's been laying down for about five years. It was a stringer for our first log load, which shortly after finishing the load was covered by a few dump truck loads of pine rounds.
    Never did get around to it, not wanting to dull a chain going through the mud casing the bottom of it. One of our astute members (Urban Woods, thanks!) in that other thread lit the light bulb for me, suggesting the bark would probably slough right off after sitting around for so long.
    It worked out pretty well, and I got it processed this afternoon. Not really feeling great the last couple days, so it was a nice short chore to get some fresh air and not feel like the whole day was wasted. There was virtually no rot, to my surprise, and only a little punk around a seam where the tree might have lost a branch or been injured a while back.
    Moisture was measured between 22-25 percent, but that's at 32 degrees or so. I've got a piece inside to warm up so I can split fresh get a more accurate reading. I don't know if cold requires an adjustment up or down.
    -edit- the real ugly stuff is a couple rounds of yellow birch that didn't fare as well. I did unzip them back in the day, but only the splits from the unzipped area weren't punky.
  2. Chaz
    Chaz
    Southwestern NY
    Nice write-up BigPapi
    :yes:
    Honestly, I'm not surprised that log fared very well, but will admit I was wondering how it fared.
    :sherlock:
    Ash may not be the best BTU's, but I will miss it when it's gone.
    Well, when I get after my dead and dying ones, I'll have years worth to put up.
  3. Canadian border VT
    Ash is a great wood, I've split a bunch..
  4. amateur cutter
    Nice work BigPapi , bummer you don't feel well. Ash IMHO is one of the best all around fire woods. Rot resistant as you know, relatively low MC right from the start, decent BTU's & quick drying. Get all you can. As for cutting at the bottom of the pile, debarking & I use semi chisel chain on a log deck. Holds up better to the dirt & will tolerate a lower raker height without getting real grabby. Bottom line, more cutting & less sharpening.
  5. BigPapi
    BigPapi
    Semi chisel is something I should look into. I cut enough grungy wood it would be a good idea. Thanks for the tip!
    Planning on feeling better quick.. I spent a few days away from home for work, and the takeout food did a number on me! Going to bring a cooler full of leftovers next time I think.
    After my split warmed to room temperature, I split it again and got 29%-31% on the fresh split face, thus proving what we all know.. Logs don't dry much internally until you css! Stacked it with the silver/sugar maple pile for 2020.
