Tools of the trade or your inventions
Discussion in 'The Wood Pile' started by T.Jeff Veal, Oct 2, 2018.
  1. Blondy Tom
    Blondy Tom
    Limerick
    The best thing about this box is when you keep everything together you are far less likely to forget to bring something with you when you travel into the woods or some remote workplace.
  2. Stlshrk
    Stlshrk
    Central Virginia
    Blondy Tom, and hopefully avoid leaving gear in the woods. When the box is full, you're all packed up. :saw::dremel::quad:
  3. T.Jeff Veal
    Great idea
    Screwloose, Woodsnwoods and Stlshrk like this.
  4. Boogeyman
    Boogeyman
    Central Indiana
    I do something similar for my saw stuff, I didn't make it to hold saws though. Great way to keep stuff together. 20181014_204352.jpg
  5. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Slight addiction CBB3CA07-4660-41BF-ADB8-6CF33D4E1BD9.jpeg 1C259DBA-C759-4E90-887A-692C0C1FA6CF.jpeg BE8BD652-6631-42CF-8B4E-6DF0C6025440.jpeg 8F25077C-C933-4C2D-B008-675FC4200F91.jpeg 317D8C23-7842-4D90-BED9-F0AF6614570D.jpeg 2B5ED636-CA9C-4D91-951D-6DA27AFD0991.jpeg 2AA82266-4BF9-4264-86AC-449C81A9D4C9.jpeg 59C04773-67F3-4BCA-8995-EB981B53A615.jpeg
  6. Erik B
    Erik B
    Western Wisconsin
    Recently finished making a dray for hauling logs.
  7. T.Jeff Veal
  8. Stlshrk
    Stlshrk
    Central Virginia
    This is a hand truck converted to a small wood cart. I use it to load out the boiler. 20181109_200047.jpg 20181109_200423.jpg
  9. Thor
    Thor
    Genoa City,Wi
    That is a well thought out system you made!
  10. GrJfer
    GrJfer
    The Woods of Arkansas
    I don't have all the big mechanical help of some of the things I've seen here. I do have a couple small things that I use regularly especially splitting. The small Hatchet is great for cutting apart some of the stringy pieces, and a breaker bar is great for leverage moving some of the bigger rounds around.
    Can't forget the Grizzly removing splitter around.
  11. T.Jeff Veal
    I see you have the board in front of he foot now. Nice. Just a suggestion, if you can get it a shade higher than the tips on the foot, the blocks will slide on easier.
  12. GrJfer
    GrJfer
    Totally understand. It was just a piece I had handy.
  13. Stlshrk
    Stlshrk
    Central Virginia
    I love this thread and ones like it! It is full of folks adapting and overcoming the things that stop or slow us down. And, best of all, sharing with the rest of us.
    The pix that follow show an ATV chainsaw bracket that I adapted and attached to the FEL on our Kubota L3901. It was one of my best purchases ever at a $6 cost on sale.
    Even if I'm not working firewood, I do like to have a saw along on the tractor. No matter if it is working at a hunting property, bush hogging, or doing anything unrelated to firewood, a downed limb or tree in a trail can derail us all. :headbang:
    The bracket itself works pretty great. So, why not fiddle with it? :whistle: LOL
    The time it takes to loosen the wing nut, and/or remove a glove to do so, has grown to annoy me. I know, we are talking about a whopping 30 seconds, at most. I'm not sure what I expect really. Some sort of quick draw saw competition... The saw down at the O.K. Coral?
    Anyway, I removed the bolt and wing nut to add a toggle latch that I had salvaged from something else. Now securing or removing the saw from the bracket is not only much faster, but I can do it while still using gloved hands. :saw:
  14. LodgedTree
    LodgedTree
    I forgot to add my stick rake I built to this thread.
    After logging last winter, my fields were covered with sticks because the !@#$%^ logger was not bright enough to drive around the edge of the field, and cut right across it. Wanting to get the limbs rolled out of the field before the grass came up and it was time to hay, I welded up a stick rake to go on my 3 point hitch.
    I was shocked that it worked as good as it did too!
    There was no way I was going to walk around acres of field hand loading sticks onto a trailer. Granted with this thing I can only roll them one way so I have to make sweeping passes, but its better to sit on your katukus and circle a field, then it is to pick up sticks by hand.
    The screens are so that the stick rake can rake up plowed ground and filter out the dirt, and just windrow the rocks. Guards can be zip-tied to the rake if a person wants to rake sticks out of the way.
  15. LodgedTree
    LodgedTree
    I am not sure this would work, but I am thinking that it might be possible to use this same implement with the guards attached to widen out my road (of snow) after my v-plow goes through. I am not sure if the tines would dig into frozen ground enough to spin and transfer the snow to the outside track or not.
  16. amateur cutter
    Moved some totes of wood to the boiler today, & had an extra tank from a cage I gave away, so rather than waste it this is what I did. Plastic pallet underneath, cut the top off & fill with dry Maple. Holds about a 1/4 cord.
    webby3650, Yawner, Screwloose and 3 others like this.
  17. Timberdog
    Timberdog
    Az
    I really like these timber claws. Saves my back and makes carrying heavy rounds around a lot easier. Kind of like carrying a suitcase.
    Yawner, ABOrman, Stlshrk and 2 others like this.
  18. T.Jeff Veal
    I have the metal folding kind with top handle, only 1 set. I pulled a muscle in my back carrying a heavy round on one side, be careful.
  19. buZZsaw BRAD
    firestarter, fuelrod, Yawner and 4 others like this.
  20. Timberdog
    Timberdog
    Az
    :yes:
    T.Jeff Veal and Screwloose like this.
