First look up chimney ... aluminum can?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Lucy, Nov 4, 2018.
  1. Lucy
    Lucy
    Arkansas
    Had a look up the chimney yesterday, mostly clean but a few flaky things towards the top.
    It kind of looks like paper but i haven't burned any what is it? You may have to zoom in to see the top. My phone doesn't zoom.
    What do you guys think of burning aluminum cans? Is it worth it?
  2. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Definitly dont burn a can. Go to your local hearth, farm and home, Menards, etc that sells wood burning appliances. Look for some Creosote destroyer/remover and follow the directions on the container. Generally a powder that you sprinkle x amount on a medium hot fire.
    It doesn't look too bad, may have been a little build up that got warmer and dried out and is now flaking off. How long have you been burning?
  3. Horkn
    I wouldn't worry about that.
  4. saskwoodburner
    saskwoodburner
    I tend to get more of that flaky fluffy stuff earlier in the season with 2 cold starts a day, or with shed crud barky wood, or surprisingly, when I've run too much air. I think it pulls ashes up and sticks to smoke condensation that hasn't left the pipe at the start of the burn. But I'll bet you a piece of poplar:D that everything you're looking at would brush out to bare chimney with your hand or a rag. It's fluffy light brown stuff that won't ignite with a torch held to it for 10 minutes.
  5. Scotty Overkill
    The flakes (ones that look a lot like instant potatoes) are normal, and aren't a big concern. Now when you have huge amounts of clumps (like globs of popcorn) you've got big issues to worry about.
    Those who season their wood properly rarely have anything to worry about. And I know for a fact you fall into that good category!
  6. Scotty Overkill
    As for anti-creosote products, I'm not real crazy about using them if you have stainless steel chimneys. It's a chemical reaction, combined with heat, and who knows what that can do to your pipe.
    I know they say not to burn P/T wood in your appliances, not just because of the poison smoke it emits but also because there are copper sulfates in that wood that can react with your stainless chimney pipe.
    Do a bunch of research before using those types of products.
    Chaz, Maina, papadave and 8 others like this.
  7. Horkn
    I agree. If you are worried about the chimney, then give it a sweep.
  8. fox9988
    fox9988
    NW Arkansas 72717
    Some anti-creo products may work. Dry wood and good burning habits do work. If in any doubt give it a quick brushing. Take a pic of what comes out and post here on the forum. Residue (basically ash) left after good burning is not flammable.
    bert the turtle, Chaz, Maina and 6 others like this.
  9. brenndatomu
    Perfect chimney for a bottom up cleaning with a Soot Eater too...poke the 1st SE pole/head through a trash bag, tape bag on the bottom of the tee, open stove door (to let the chimney "breath" well), clean chimney. The dust will be sucked up the chimney, any bigger pieces will be in the bag :yes:
    Chaz, Maina, moresnow and 5 others like this.
  10. billb3
    Probably go away when it gets cold and you start burning regular.
    I wouldn't burn anything but well seasoned wood.
    Chaz, papadave, Horkn and 5 others like this.
  11. edyit
    edyit
    Wilmington NY
    the anti creosote products doesn't remove creosote in the pipe, they change the form of gooey tarry creosote to an easier to clean crunchy form, burning can's doesn't do anything at all, it's an old wivestale, like burning pine will cause chimney fires and make you go bald.
    Chaz, papadave, Horkn and 4 others like this.
  12. Lucy
    Lucy
    Arkansas
    Thanks guys for all the suggestions. Didn't really think aluminum cans sounded a good idea but saw it all over the place and just had to ask.:whistle:
    Another one i keep hearing that actually makes some sense to me is a hot fire first thing in the morning. I did that the last couple of days with a couple cedar splits because the night burns have been pretty low temp not filling the stove up much.
    My question is how hot is hot? What temps are we talking and for how long?
    Chaz, saskwoodburner, Horkn and 2 others like this.
  13. Lucy
    Lucy
    Arkansas
    Billb3, i think i will really like this stove. Overnight is unreal. Filling for the night around 10 PM with only 3 med splits of moth-eaten ( bugs been into it) but dry 14 or so oak. Still had enough coals to start kindling at 8 this morning. The house was at 69 and outside about 45. As for the rest of my fire wood most of it is under 15. I'm splitting a bunch of oak rounds right now that had been stacked outside under a piece of metal. they are more like 18 in side and wetter outside. It's been raining a lot. Hopefully i won't need them until next year.
  14. Backwoods Savage
    Lucy, that part about burning a hot fire first thing in the morning is part of that old wives tale about pine. That's how old timers usually got into problems. They would creosote up the chimney then run a hot fire. Result? I think you know.
    That flaky stuff right at the top is normal and usually nothing to be concerned with. It happens because it is the furthest from the heat and as the smoke cools, that flaky stuff is the result. We get some now and then right at the very top. Yet, my wife just got a bug up her ... the other day and decided the chimney had to be cleaned. After all, it had been 2 years at least since it was cleaned. So, she cleaned it. Result? Not even enough ash to cover the bottom of a small bucket. That is the result of good burning practices and a great stove.
  15. edyit
    edyit
    Wilmington NY
    a lot of that is going to depend on 1: your heating needs and 2: how much wood you load in the stove. but you should always avoid a smoldering fire, this is what will give you creosote. Use the thermometer as a rough guide, keep stove top temps under 800F and flue temps under 1000F and you'll be good to go. also keep in mind that when you've hit the end of the burn cycle and its just coals in the stove you're not going to get anything that forms creosote, all the volatile stuff is burned off.
  16. Lucy
    Lucy
    Arkansas
    :hair::hair::hair:you all probably think i'm crazy. That last bit of advice about the hot morning burn came from a chimney sweep:whistle:. However, not to clean the chimney but to keep it clean to start with.
    Today it is completely wind still, drizzly weather about 50 outside but feels cold. So i put a couple of cedar pieces on the coals this morning and let them burn, all fine and then i added a couple Kentucky Coffee splits also very dry wood and they started out ok but then quit and are sitting in there very slowly being reduced to ashes no flames at all no smoke either that i can tell. That wouldn't be smoldering would it? Everything is wide open. The splits only start flames when i open the door. It's warm enough no problem, the house is a cozy 73.
  17. In the Pines
    In the Pines
    I would call that smoldering. It also could just be not enough fuel in the box to keep the flames going.
    The box may not be hot enough to sustain flames. Or there could be a issue with the wood itself as well.
    Dry on the outside but the center still has too much moisture? Doesn't sound like it though from your description.
    I don't burn unless I can have a full load in there burning. If the house is warm, I will wait and let it get to coals, and start a new fire.
    A good burn is better for the stack than a small load barely burning. At least that is how I believe it to be.
    Chaz, Backwoods Savage and Lucy like this.
  18. billb3
    That stove tends to burn front to back.
    Towards the end of a burn you should be noticing there's still wood in the back, coals towards the center and ashes front and center.
    Often it's possible to pull the last coals hiding in the back with a rake or shovel right up to the door, set some kindling on them, some splits on top of them, open the stove damper to the "boost" position, watch the coals light up bright and red from the burst of air and ignite the kindling. Then watching the flame heights knock the air back in increments, getting the air lever where it needs to be to have proper stove top temps.
    I find "boost" works better than leaving the door open. Makes a lot less smoke. Not none. Less.
    Chaz, Backwoods Savage, Lucy and 2 others like this.
  19. edyit
    edyit
    Wilmington NY
    generally speaking these stoves burn "best" in batches, load stove full with air wide open, get load of wood burning well, turn air down in stages to its lowest point (this varies from install to install for some its full closed for others it can be less, draft and outside temps play a big part in this) repeat in ~8 hours. this burns cleaner and more efficiently than just throwing a split in every now and then.
  20. shack
    shack
    Upstate NY
    I have seen that stuff in the shops...does it really work or make a difference?
